doemaas
1
Even after adding the certs I still get the Duplicati.Library.Modules.Builtin.CheckMonoSSL-MissingCerts warning.
Downloaded the certs:
curl -O https://curl.haxx.se/ca/cacert.pem
Added the certs (128 added) to the root as well as me:
sudo cert-sync --user cacert.pem
ps aux revealed the Duplicati and mono processes are run as root.
Any other way to resolve this?
Fiddled around a bit more.
Don’t know where these certs go. If you do, let us know!
But this does not work correctly on systems without the root account enabled.
Solution:
First do
sudo su
Using
certmgr -list -c Trust
came up empty
Then
All certs are now correctly listed with
These certs are in:
/var/root/.config/.mono/certs/Trust
Then the warning disappears.
Great step-by-step solution. Thanks for that! I’ll be marking it as Solved, if you have any other problems please let me know to undo this action
