2.0.3.7 on Mac: CheckingErrorsForIssue1400
after updating my mac from beta to 2.0.3-7 canary I get these errors.
Warnings: [ 2018-06-18 07:40:35 +02 - [Warning-Duplicati.Library.Modules.Builtin.CheckMonoSSL-MissingCerts]: No certificates found, you can install some with one of these commands: cert-sync /etc/ssl/certs/ca-certificates.crt #for Debian based systems cert-sync /etc/pki/tls/certs/ca-bundle.crt #for RedHat derivatives Read more: Release Notes Mono 3.12.0 | Mono, 2018-06-18 07:41:42 +02 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /Users/manderss99/.config/Duplicati/DPLCDKDHLW.sqlite-journal ] Errors: [ 2018-06-18 07:41:42 +02 - [Error-Duplicati.Library.Main.Database.LocalBackupDatabase-CheckingErrorsForIssue1400]: Checking errors, related to #1400. Unexpected result count: 0, expected 1, hash: cRq+MFby0LayGdrGFYMt2dL6Do3c6+Ai32UFXg01f7o=, size: 6216, blocksetid: 99529, ix: 18, fullhash: DO+CiX03U75nRm3HGTIxw3fhjFAWr4CUhQGbT+Ao20w=, fullsize: 1849416, 2018-06-18 07:41:42 +02 - [Error-Duplicati.Library.Main.Database.LocalBackupDatabase-FoundIssue1400Error]: Found block with ID 379355 and hash cRq+MFby0LayGdrGFYMt2dL6Do3c6+Ai32UFXg01f7o= and size 5184 ]
Note:
The update process from within duplicati also fails to restart duplicati, noted this this time and also when updating from experimental to beta. Had to reboot to get duplicati running.
pls anyone,
how do I fix this issue1400 thing?
thanks
After some more searching I excluded the duplicat config directory and the error goes away.
Not sure if this is a proper workaround though.
This did not happen on the previous beta version I was running.
Interesting! That indicates that we still have a problem with backing up files that are actively modified.
After further testing I’ve narrowed it down:
exclude file extension sqlite-journal does fix the issue.
The SSL certificates warning remains though (see other thread)
