Most of the time (as in every time I’ve tried except two), Duplicati won’t open. The error message I get is “You cannot open Duplicati.app because it is not responding.” My first backup (75 GB to a remote WebDAV server) is in progress and likely to take several hours. I have not been able to open Duplicati since closing the web page that showed status. Is this normal? Will I be able to launch it once the current backup is done?
When Duplicati is running, you should have a small icon in the status bar (top right of the screen). You can use this to re-open the web interface after you close it.
Not sure why it says “not responding”, it should not do that.
There it is! Thanks!
