Hi all,
I’m using duplicati to back up ~250GB to OneDrive (personal). Setting everything up worked like a charm using this guide: Setting up OneDrive (personal)
I had to set the accept-any-ssl-certificate option to make things work though (I followed the SSL guides with no success).
Starting the backup works, however, after some time the backup breaks with the following error message:
Failed to authorize using the OAuth service: Error: TrustFailure (The authentication or decryption has failed.). If the problem persists, try generating a new authid token from: Duplicati OAuth Handler
It doesn’t mater if I follow this advice or not, a restart of the backup works and breaks again after some time.
Is there anything I can try to make this work?
My duplicati version is: Duplicati - 2.0.2.1_beta_2017-08-01
My system is this:
System properties
APIVersion : 1
PasswordPlaceholder : **********
ServerVersion : 2.0.2.1
ServerVersionName : - 2.0.2.1_beta_2017-08-01
ServerVersionType : Beta
BaseVersionName : 2.0.2.1_beta_2017-08-01
DefaultUpdateChannel : Beta
DefaultUsageReportLevel : Information
ServerTime : 2018-01-12T19:53:50.12442+01:00
OSType : Linux
DirectorySeparator : /
PathSeparator : :
CaseSensitiveFilesystem : true
MonoVersion : 4.6.2
MachineName : aswift
NewLine :
CLRVersion : 4.0.30319.42000
CLROSInfo : {"Platform":"Unix","ServicePack":"","Version":"4.10.0.42","VersionString":"Unix 4.10.0.42"}
ServerModules : []
UsingAlternateUpdateURLs : false
LogLevels : ["Profiling","Information","Warning","Error"]
SuppressDonationMessages : false
SpecialFolders : [{"ID":"%MY_DOCUMENTS%","Path":"/home/andre"},{"ID":"%MY_MUSIC%","Path":"/home/andre"},{"ID":"%MY_PICTURES%","Path":"/home/andre"},{"ID":"%DESKTOP%","Path":"/home/andre/Desktop"},{"ID":"%HOME%","Path":"/home/andre"}]
BrowserLocale : {"Code":"en-US","EnglishName":"English (United States)","DisplayName":"English (United States)"}
SupportedLocales : [{"Code":"de","EnglishName":"German","DisplayName":"Deutsch"},{"Code":"en","EnglishName":"English","DisplayName":"English"},{"Code":"es","EnglishName":"Spanish","DisplayName":"español"},{"Code":"fi","EnglishName":"Finnish","DisplayName":"suomi"},{"Code":"fr","EnglishName":"French","DisplayName":"français"},{"Code":"nl-NL","EnglishName":"Dutch (Netherlands)","DisplayName":"Nederlands (Nederland)"},{"Code":"pl","EnglishName":"Polish","DisplayName":"polski"},{"Code":"ru","EnglishName":"Russian","DisplayName":"русский"},{"Code":"zh-CN","EnglishName":"Chinese (Simplified)","DisplayName":"中文 (中国)"}]
BrowserLocaleSupported : true
backendgroups : {"std":{"ftp":null,"ssh":null,"webdav":null,"openstack":"OpenStack Object Storage / Swift","s3":"S3 Compatible","aftp":"FTP (Alternative)"},"local":{"file":null},"prop":{"s3":null,"azure":null,"googledrive":null,"onedrive":null,"cloudfiles":null,"gcs":null,"openstack":null,"hubic":null,"amzcd":null,"b2":null,"mega":null,"box":null,"od4b":null,"mssp":null,"dropbox":null,"jottacloud":null}}
GroupTypes : ["Local storage","Standard protocols","Proprietary","Others"]
Backend modules:
aftp
amzcd
azure
b2
box
cloudfiles
dropbox
ftp
file
googledrive
gcs
hubic
jottacloud
mega
onedrive
openstack
s3
ssh
od4b
mssp
tahoe
webdav
Compression modules:
zip
7z
Encryption modules:
aes
gpg
Server state properties
lastEventId : 144
lastDataUpdateId : 30
lastNotificationUpdateId : 13
estimatedPauseEnd : 0001-01-01T00:00:00
activeTask : {"Item1":8,"Item2":"4"}
programState : Running
lastErrorMessage :
connectionState : connected
xsfrerror : false
connectionAttemptTimer : 0
failedConnectionAttempts : 0
lastPgEvent : {"BackupID":"4","TaskID":8,"BackendAction":"List","BackendPath":null,"BackendFileSize":-1,"BackendFileProgress":0,"BackendSpeed":-1,"CurrentFilename":"/media/andre/andre_backup/bilder/2017/20170929_selin_cliff_hotel/20170929_131844_DSC01469.jpg","CurrentFilesize":5981040,"CurrentFileoffset":2048000,"Phase":"Backup_ProcessingFiles","OverallProgress":0,"ProcessedFileCount":2334,"ProcessedFileSize":12659743932,"TotalFileCount":64834,"TotalFileSize":278100596636,"StillCounting":false}
updaterState : Waiting
updatedVersion :
updateReady : false
updateDownloadProgress : 0
proposedSchedule : [{"Item1":"3","Item2":"2018-01-13T12:00:00Z"}]
schedulerQueueIds : []
pauseTimeRemain : 0
Thanks, André
