If I reboot my machine and try to launch a newly created backup job then I always see these log entries:
Failed: The creation of a shadow copy is already in progress.
Details: Alphaleonis.Win32.Vss.VssSnapshotSetInProgressException: The creation of a shadow copy is already in progress.
bei Alphaleonis.Win32.Vss.VssBackupComponents.StartSnapshotSet()
bei Duplicati.Library.Snapshots.WindowsSnapshot…ctor(IEnumerable1 sources, IDictionary
2 options)
bei Duplicati.Library.Snapshots.SnapshotUtility.CreateWindowsSnapshot(IEnumerable1 folders, Dictionary
2 options)
bei Duplicati.Library.Main.Operation.BackupHandler.GetSnapshot(String sources, Options options)
bei Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__19.MoveNext()
— Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde —
bei System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
bei CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task)
bei Duplicati.Library.Main.Controller.<>c__DisplayClass13_0.<Backup>b__0(BackupResults result)
bei Duplicati.Library.Main.Controller.RunAction[T](T result, String& paths, IFilter& filter, Action`1 method)
Log data:
2019-04-05 17:37:58 +02 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
2 options)
2 options)
X-Laufwerk-duplicati-config(1).zip (829 Bytes)
I have uploaded the backup job as .zip - maybe one of the experts here is able to tell me what I am doing wrong …
Duplicati is running as a service under my user credentials - other backup jobs are working.
My guess is that the network share (source) causes the troubles but I have got all the privileges …
