Warnings after backing up from new drive
I’ve been upgrading my hard drive and copied all the data exactly from the old drive to the new one. Then I changed the source in the configuration to the new hard drive but unfortunately it gave some warnings:
ParsedResult: Success
EndTime: 25-8-2018 08:07:55 (1535177275)
BeginTime: 25-8-2018 08:07:33 (1535177253)
Duration: 00:00:22.1166140
ParsedResult: Warning
BeginTime: 25-8-2018 08:00:00 (1535176800)
Duration: 00:07:55.3449430
Messages: [
Deleting 1 remote fileset(s) …,
Deleted 1 remote fileset(s),
Compacting not required
Warnings: [
Error reported while accessing file: /media/path/to/drive/.Trash-0/ => Access to the path “/media/path/to/drive/.Trash-0” is denied.,
Errors:
Everything does work but what does this mean and should I (and how) fix it? I never new there was a hidden Trash-0 folder. Thank you in advance.
Solution
The folder .Trash-0 was missing on my hard drive and had nothing to do with Duplicati. I created one by removing a file on the drive as root (thus creating a trash dir).
Thanks for sharing what you figured out.
I’m sure if you had a that folder explicitly included in your backup as otherwise Duplicati wouldn’t normally give a warning about a “missing” folder
