The alt.updates.duplicati.com is completely down (through browser ) and updates.duplicati.com Shows 502 Bad Gateway.
I also got before sometimes error while updating (Downloads update and after it should be done again asks to update and I can let it install again and again and it will Show the update until I hide the message).
It Shows:
- OSType : Linux
- ServerTime : 2019-03-01T08:08:47.932729+01:00
- DefaultUsageReportLevel : Information
- DefaultUpdateChannel : Beta
- BaseVersionName : 2.0.3.3_beta_2018-04-02
- StartedBy : Server
- ServerVersionType : Beta
- ServerVersionName : - 2.0.4.5_beta_2018-11-28
- ServerVersion : 2.0.4.5
Also a backup erros almost at the end and when I try to repair it Fails (how can I delete the database manually, saw that in canary there was something fixed).
I also switched to canary, but it still could not find any new Version.
The error at the end of backup (Backup of Nextcloud File Folder, the Folder may have got small changes while backup, but backup of around 540G takes around 21 Hours so I would like not to stop Nextcloud completely in the meantime. CPU is old (Intel G630) and has no AES-NI):
- Mrz. 2019 06:12: Failed while executing “Backup” with id: 7
System.AggregateException: One or more errors occurred. —> System.AggregateException: The channel is retired —> CoCoL.RetiredException: The channel is retired at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter
1[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at CoCoL.Channel
1+<WriteAsync>d__30[T].MoveNext () [0x00196] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 — End of stack trace from previous location where exception was thrown — at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Duplicati.Library.Main.Operation.BackupHandler+<FlushBackend>d__18.MoveNext () [0x000a1] in <c6c6871f516b48f59d88f9d731c3ea4d>:0 — End of stack trace from previous location where exception was thrown — at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Duplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__19.MoveNext () [0x00cc0] in <c6c6871f516b48f59d88f9d731c3ea4d>:0 --- End of inner exception stack trace --- at Duplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__19.MoveNext () [0x01033] in <c6c6871f516b48f59d88f9d731c3ea4d>:0 --- End of inner exception stack trace --- at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x0005d] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x00008] in <c6c6871f516b48f59d88f9d731c3ea4d>:0 at Duplicati.Library.Main.Controller+<>c__DisplayClass13_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x00035] in <c6c6871f516b48f59d88f9d731c3ea4d>:0 at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action
1[T] method) [0x0011d] in <c6c6871f516b48f59d88f9d731c3ea4d>:0 —> (Inner Exception #0) System.AggregateException: The channel is retired —> CoCoL.RetiredException: The channel is retired at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter1[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at CoCoL.Channel
1+<WriteAsync>d__30[T].MoveNext () [0x00196] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 — End of stack trace from previous location where exception was thrown — at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Duplicati.Library.Main.Operation.BackupHandler+<FlushBackend>d__18.MoveNext () [0x000a1] in <c6c6871f516b48f59d88f9d731c3ea4d>:0 — End of stack trace from previous location where exception was thrown — at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Duplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__19.MoveNext () [0x00cc0] in <c6c6871f516b48f59d88f9d731c3ea4d>:0 --- End of inner exception stack trace --- at Duplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__19.MoveNext () [0x01033] in <c6c6871f516b48f59d88f9d731c3ea4d>:0 ---> (Inner Exception #0) CoCoL.RetiredException: The channel is retired at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter
1[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at CoCoL.Channel1+<WriteAsync>d__30[T].MoveNext () [0x00196] in <6973ce2780de4b28aaa2c5ffc59993b1>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Duplicati.Library.Main.Operation.BackupHandler+<FlushBackend>d__18.MoveNext () [0x000a1] in <c6c6871f516b48f59d88f9d731c3ea4d>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable
1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at Duplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__19.MoveNext () [0x00cc0] in <c6c6871f516b48f59d88f9d731c3ea4d>:0 <— ---> (Inner Exception #1) System.AggregateException: One or more errors occurred. —> System.Exception: Die Datei duplicati-ic9b8fa75fa3948fcb007389cfe15bf31.dindex.zip.aes wurde hochgeladen, aber anschließend nicht gefunden. Ausgabe der Dateiliste: . …
