I am running Duplicati 2.0.5.114_canary_2021-3-10
Update check does not report current or new version available. Is this by design because the build is Canary? Previous versions reported running most current version. This one does nothing. Just blink.
Checking the website manually, I find version 2.0.6.1 beta is available.
Yes. It checks for updates for whatever channel you’re in. 2.0.5.114 is the latest Canary.
You can find your channel in About → System info, e.g. DefaultUpdateChannel : Canary
You can find it and control it in Settings. A fresh install changes channel type to its type.
Are you sure? 2.0.5.114_canary_2021-03-10 is extremely close to 2.0.5.113, per that link.
I don’t think this can be tried on previous versions now because now there are new ones.
C:\ProgramData\Duplicati\duplicati-2.0.5.114_canary_2021-03-10>Duplicati.Library.AutoUpdater.exe check
No updates found
C:\ProgramData\Duplicati\duplicati-2.0.5.114_canary_2021-03-10>Duplicati.Library.AutoUpdater.exe install
You are running the latest version: 2.0.5.114_canary_2021-03-10 (2.0.5.114)
