Hello. I have 80+ files from a backup made in 2014 and receive an error message when I try to restore them. I tried to do a direct restore from backup using duplicati 2, which I think is a newer version then the duplicati that I used for my original back up back in 2014. I designate the local drive in which I have the backup files, I tested connection which works, and then I received the following error message.Failed to connect: “No filesets found on remote target”.
In my destination folder I have manifest A&B files, 43 volumes of signature files, and 43 files of full content, which are named in the following manner, for example. I have assured that for every content there is an equivalent signature file for the appropriate volume.
duplicati-full-manifestA.20140415T125521Z.manifest
duplicati-full-signature.20140415T125521Z.vol1.zip
duplicati-full-content.20140415T125521Z.vol39.zip
is this old backup compatible with the restore function of duplicati 2? Or am I missing something in my original backup files?
Thank you in advance for your assistance in this issue.
In case it is relevant I am using Windows 10 pro on a Chrome browser on a Microsoft Surface Pro.
