The operation Repair has failed with error: The database was attempted repaired, but the repair did not complete. This database may be incomplete and the repair process is not allowed to alter remote files as that could result in data loss.
How to fix this?
Sep 24, 2019 7:43 AM: The operation Repair has failed with error: The database was attempted repaired, but the repair did not complete. This database may be incomplete and the repair process is not allowed to alter remote files as that could result in data loss.
{“ClassName”:“Duplicati.Library.Interface.UserInformationException”,“Message”:“The database was attempted repaired, but the repair did not complete. This database may be incomplete and the repair process is not allowed to alter remote files as that could result in data loss.”,“Data”:null,“InnerException”:null,“HelpURL”:null,“StackTraceString”:" a következő helyen: Duplicati.Library.Main.Operation.RepairHandler.RunRepairRemote()\r\n a következő helyen: Duplicati.Library.Main.Operation.RepairHandler.Run(IFilter filter)\r\n a következő helyen: Duplicati.Library.Main.Controller.RunAction[T](T result, String& paths, IFilter& filter, Action`1 method)\r\n a következő helyen: Duplicati.Library.Main.Controller.Repair(IFilter filter)\r\n a következő helyen: Duplicati.Server.Runner.Run(IRunnerData data, Boolean fromQueue)",“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:“8\nRunRepairRemote\nDuplicati.Library.Main, Version=2.0.4.23, Culture=neutral, PublicKeyToken=null\nDuplicati.Library.Main.Operation.RepairHandler\nVoid RunRepairRemote()”,“HResult”:-2146233088,“Source”:“Duplicati.Library.Main”,“WatsonBuckets”:null}
