Just updated my CentOS linux box to 2.0.4.4. One of my backup fails complaining about being unable to find the tempdir:
System.IO.FileNotFoundException: Could not find file '/backups/duplicati/tmp'.
File name: '/backups/duplicati/tmp'
at Duplicati.Library.Main.BackendManager.List () [0x00049] in <365e0052627a43cbb8447250519b5a7f>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.String protectedfile) [0x0000d] in <365e0052627a43cbb8447250519b5a7f>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.String protectedfile) [0x00000] in <365e0052627a43cbb8447250519b5a7f>:0
at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify (Duplicati.Library.Main.BackendManager backend, System.String protectedfile) [0x0010d] in <365e0052627a43cbb8447250519b5a7f>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x01028] in <365e0052627a43cbb8447250519b5a7f>:0
at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x00050] in <6973ce2780de4b28aaa2c5ffc59993b1>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter) [0x00008] in <365e0052627a43cbb8447250519b5a7f>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass13_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x00035] in <365e0052627a43cbb8447250519b5a7f>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x00271] in <365e0052627a43cbb8447250519b5a7f>:0
at Duplicati.Library.Main.Controller.Backup (System.String[] inputsources, Duplicati.Library.Utility.IFilter filter) [0x00068] in <365e0052627a43cbb8447250519b5a7f>:0
at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x00307] in <6abd47b91a774213b482ed288fd091a2>:0
I have the following options:
--tempdir=/backups/duplicati/tmp/
--use-move-for-put=true
--disable-streaming-transfers=true
Of course, this has worked with all prior versions. I can see that it is putting some files in the tempdir, so it is finding the directory sometimes.
-rw-r--r--. 1 root root 338 Nov 27 12:08 dup-277568cc-d8c3-4491-b9ff-5bfb57263aaa
-rw-r--r--. 1 root root 338 Nov 27 11:52 dup-38559108-7267-4aa8-8374-f075eb699ac0
-rw-r--r--. 1 root root 337 Nov 27 12:28 dup-3b238b68-95d3-4889-b947-2508cbefd447
Hope this helps.
