Whenever I click Test connection with a Storage Type of SFTP (SSH) the server crashes. If I run /Applications/Duplicati.app/Contents/MacOS/duplicati-server manually I see the following before the process crashes …
[ERROR] FATAL UNHANDLED EXCEPTION: System.ObjectDisposedException: Safe handle has been closed
at System.Runtime.InteropServices.SafeHandle.DangerousAddRef (System.Boolean& success) [0x0001c] in <bb7b695b8c6246b3ac1646577aea7650>:0
at System.Threading.NativeEventCalls.SetEvent (Microsoft.Win32.SafeHandles.SafeWaitHandle handle) [0x00002] in <bb7b695b8c6246b3ac1646577aea7650>:0
at System.Threading.EventWaitHandle.Set () [0x00000] in <bb7b695b8c6246b3ac1646577aea7650>:0
at (wrapper remoting-invoke-with-check) System.Threading.EventWaitHandle.Set()
at Renci.SshNet.Abstractions.SocketAbstraction.ConnectCompleted (System.Object sender, System.Net.Sockets.SocketAsyncEventArgs e) [0x0000f] in <502177f7126d48e4be01a83c8cdb4c79>:0
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted (System.Net.Sockets.SocketAsyncEventArgs e) [0x0000e] in <f8bb3922e51744d9ace1aa6aedc374ea>:0
at System.Net.Sockets.SocketAsyncEventArgs.Complete () [0x00000] in <f8bb3922e51744d9ace1aa6aedc374ea>:0
at System.Net.Sockets.Socket+<>c.<.cctor>b__308_3 (System.IAsyncResult ares) [0x00057] in <f8bb3922e51744d9ace1aa6aedc374ea>:0
at System.Net.Sockets.SocketAsyncResult+<>c.<Complete>b__27_0 (System.Object state) [0x0000b] in <f8bb3922e51744d9ace1aa6aedc374ea>:0
at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem () [0x00008] in <bb7b695b8c6246b3ac1646577aea7650>:0
at System.Threading.ThreadPoolWorkQueue.Dispatch () [0x00074] in <bb7b695b8c6246b3ac1646577aea7650>:0
at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback () [0x00000] in <bb7b695b8c6246b3ac1646577aea7650>:0
I am able to SSH to the server without issue. I’ve specified a working ssh-keyfile. I’m using …
- MacOS High Sierra 10.13.5 (the SSH server is the same, but I’ve tested a Linux server as well with the same results)
- Duplicati - 2.0.3.3_beta_2018-04-02
- Mono JIT compiler version 5.10.1.47 (2017-12/8eb8f7d5e74 Fri Apr 13 20:18:12 EDT 2018
I’m using the same setup on other machines on the network without issue. However they are using Duplicati - 2.0.2.1_beta_2017-08-01.
Help!
Frank
