I recently started using Duplicati on a Windows 10 machine, and after restarting my computer I noticed that the program didn’t start. Trying to boot it from the link on my desktop, nothing appeared to happen. Digging around a bit, I found the updates/Duplicati-crashlog which had been recently generated and read as follows:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Exception: A serious error occurred in Duplicati: System.BadImageFormatException: The module was expected to contain an assembly manifest. (Exception from HRESULT: 0x80131018)
at System.Reflection.RuntimeAssembly.nLoadFile(String path, Evidence evidence)
at System.Reflection.Assembly.LoadFile(String path)
at Duplicati.Library.SQLiteHelper.SQLiteLoader.get_SQLiteConnectionType()
at Duplicati.Server.Program.GetDatabaseConnection(Dictionary`2 commandlineOptions)
at Duplicati.Server.Program.RealMain(String[] _args) ---> System.BadImageFormatException: The module was expected to contain an assembly manifest. (Exception from HRESULT: 0x80131018)
at Duplicati.GUI.TrayIcon.HostedInstanceKeeper..ctor(String[] args)
at Duplicati.GUI.TrayIcon.Program.RealMain(String[] _args)
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Duplicati.Library.AutoUpdater.UpdaterManager.RunMethod(MethodInfo method, String[] args)
Is this a fixable error?
