Hello,
I’ve just installed Duplicati on my DS718+ but I can’t launch the package. I’ve no error message.
Here’s the step of what I’ve done :
- Install the “Mono” package from the beta program and it as launch automatically
- Install the last Duplicati version manualy
-> The package was started automatically be I got an error where Duplicati cannot access to the server (something like that). - I’ve stopped it and re launch it. But I’ve never succeed to launch it again…
Here is my mono version :
Rian@RianAS:~$ mono -V
Mono JIT compiler version 4.6.2 (Stable 4.6.2.16/ac9e222 Fri Oct 27 17:00:53 CST 2017) Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com TLS: __thread SIGSEGV: normal Notifications: epoll Architecture: amd64 Disabled: profiler,logging,debug,soft_debug Misc: LLVM: supported, not enabled. GC: sgen
Here’s the version of Duplicati :
Rian@RianAS:~$ duplicati-cli --help See duplicati.commandline.exe help <topic> for more information. General: example, changelog Commands: backup, find, restore, delete, compact, test, compare, purge, vacuum Reparing: repair, affected, list-broken-files, purge-broken-files Debugging: debug, logging, create-report, test-filters, system-info, send-mail Targets: aftp, amzcd, azure, b2, box, cloudfiles, dropbox, ftp, file, googledrive, gcs, hubic, jottacloud, mega, onedrive, openstack, rclone, s3, ssh, od4b, mssp, sia, tahoe, webdav Modules: aes, gpg, zip, 7z, console-password-input, mssql-options, hyperv-options, http-options, sendhttp, sendmail, runscript, sendxmpp, check-mono-ssl Formats: date, time, size, encryption, compression Advanced: mail, advanced, returncodes, filter, default-filter-sets, <option> http://www.duplicati.com/ Version: - 2.0.3.3_beta_2018-04-02
The dir /root/.config :
ash-4.3# pwd /root/.config/Duplicati ash-4.3# find . -not -path '*/\.*' | python -c "import sys as s;s.a=[];[setattr(s,'a',list(filter(lambda p: c.startswith(p+'/'),s.a)))or (s.stdout.write('|'*len(s.a)+c[len(s.a[-1])+1 if s.a else 0:])or True) and s.a.append(c[:-1]) for c in s.stdin]" . |control_dir_v2 ||lock_v2 |Duplicati-server.sqlite ash-4.3# ash-4.3# cat /root/.config/Duplicati/control_dir_v2/lock_v2 14200 ash-4.3# ps aux | grep Mono root 14200 0.0 0.7 1121164 41856 ? Sl 11:35 0:02 /volume1/@appstore/Mono/usr/local/bin/mono-sgen /volume1/@appstore/Duplicati/Duplicati.Server.exe
