I think I found a bug when using --exclude with the purge command via the GUI commandline
Let’s say I am using this dataset, already created via Duplicati previously
/sharedfolders/Videos/ /sharedfolders/Music/ /sharedfolders/Others/ /sharedfolders/video1.mkv /sharedfolders/video2.mkv /sharedfolders/video3.mkv /sharedfolders/song1.mp3 /sharedfolders/song2.mp3 /sharedfolders/notes.txt
The plan was to get two copies of this dataset such that:
//Dataset 1 /sharedfolders/Music/ /sharedfolders/Others/ /sharedfolders/song1.mp3 /sharedfolders/song2.mp3 /sharedfolders/notes.txt
//Dataset 2 /sharedfolders/Videos/ /sharedfolders/video1.mkv /sharedfolders/video2.mkv /sharedfolders/video3.mkv
So I made two copies of the data and wanted to use the Purge command on each of them
If I were to use the following argument
--include="/sharedfolders/Music/*" --include="/sharedfolders/Others/*" --include="/sharedfolders/song1.mp3" --include="/sharedfolders/song2.mp3" --include="/sharedfolders/notes.txt"
This works fine for Dataset 1 but the challenge begins with Dataset 2
--include="/sharedfolders/Videos/*"
The folder “Videos” would be removed but not the individual video files at root directory. It would be ok if the numbers are just a few since I can just purge them individually by identifying them individually per line but I thought I had a better idea.
I tried this argument
--exclude="/sharedfolders/Music/*" --exclude="/sharedfolders/Others/*" --include="/sharedfolders/Videos/*" --include="/sharedfolders/*.mkv"
The following got removed
/sharedfolders/Videos/ /sharedfolders/video1.mkv /sharedfolders/video2.mkv /sharedfolders/video3.mkv /sharedfolders/song1.mp3 //I do not want this removed /sharedfolders/song2.mp3 //I do not want this removed /sharedfolders/notes.txt //I do not want this removed
In other words, it appears that using any --exclude arguments will mean everything from root directory will be included unless specifically excluded by further --exclude arguments.
Or to put it in a more “standard” bug report format:
Expected behaviour: Only specified directories ignored but no other directories excluded/included unless otherwise specified in other arguments Observed behaviour: Specified directories ignored but all other directories/files included unless specifically excluded in other arguments
May I know if this is intentional by design? Also, how would one be able to solve this problem?
