I Imported configuration. Locally I have all the data that is in the cloud and also after the last backup, I added some additional data locally. When I ran imported task I got the message: Error while running My Archive
Found 1055 remote files that are not recorded in local storage, please run repair
Please hold off on a repair until we hear some more information on what youâre doing.
Did you ever do anything like copy old local database (.sqlite file) into the new config?
If not, there is a risk of repair deleting destination data to match its empty databaseâŚ
Everything below I did on one laptop. I used Backblaze B2 as a cloud.
What I did:
I set up back up job. I write down passphrase.
Exported job config.
I ran back-up job for several times.
Updated duplicati.
I deleted the existing back-up job but I do not remember I checked also to delete database or not. I did not delete local files and have not renamed the main folder (so main folder is in place with same name).
I deleted several files and added several files from/to my local folder.
I imported backup job configuration. Added passphrase. Also checked âImport metadataâ and âSave immediatelyâ checkboxes.
I ran the backup job and received:
Itâs not clear why in step 6 the job was deleted, then brought back in step 8 from the step 2 export, however the export and import only handle the configuration (and some metadata). The local database matching the destination files needs to be brought along with those files. A new job creates a new database, but you can put the old one into the new job like this, if you still have it. I think thereâs a bug that prevents deletion when the job is deleted⌠In this case, that might help you out. I assume that old database and destination match.
Looking inside the exported config can find the old pathname in the âDBPathâ line. With luck, itâs still around, and can be placed into the restored job to match the files at destination. Probably the destination was never changed due to the error on the backup, but Job --> Show log --> Remote will show you whether it changed. Seeing list is fine, put not so bad (but might be undone). Seeing a delete might mean destination is now damaged. If itâs not damaged, itâs usually possible to slowly recreate the database out of the destination files, however finding and installing a matching database from latest backup (step 5, I hope) is the preferred path.
I could not find database, so I think it is deleted.
Here is a screenshot of the log: https://i.imgur.com/cQogPlu.jpg There is only âlistâ, so I assume no data loss.
I think it is better to recreate database.
To recreate database I need to push â[Recreate (delete and repair)â button in Database section and wait until recreation finishes, is this correct?
My backup folder is currently ~ 25 GB and has ~7000 files in it. Previously I ran backup no more than 45 times. What you think, how long database recreation will take?
Is there possibility of damaging my local files while recreating database?
Yes - to recreate the database, use the âRecreate (delete and repair)â button and have some patience.
Itâs hard to estimate how long a Recreate will take. With 7k files it likely wonât take TOO long.
A database recreate will download a few files from the destination to use to rebuild the local database but it wonât touch any of your source data files at all, so they should be fine.
A few notes:
@ts678 is correct in that renaming the local database from itâs old name to the new one (or re-pointing the imported job to the old database name) is likely much faster & safter than recreating the database.
You can paste screenshots directly into your post - for example, here 's some of my Remote log showing some GETs as well as a LIST and a DELETE:
Note that the DELETE is deleting a no-longer needed archive from the destination, itâs not deleting anything from my local machine.
Personally, Iâd suggest going to the jobâs Database menu and looking at the âLocal database pathâ field. Look in the folder referenced there and see if you have 2 .sqlite files name something like DTRMXBFMSD.sqlite (ignore the duplicati-server.sqlite file).
If you have only 2 .sqlite files and only 1 (current) backup job then most likely one file will be very small and the other relatively large. Either swap the file names OR in the Duplicati GUI change the âLocal database pathâ field to have file name of the larger .sqlite file.
This should get your original database re-attached to your imported job.
The backup 201812xxxxxx.sqlite files are backups made prior to a Recreate (or Repair?).
Duplicati-server.sqlite is the âglobalâ database so donât touch that.
The one thatâs named with all numbers is very odd - I havenât see anything with that naming convention before. Personally, Iâd check the newest date of the files at the destination and find the nearest newer date in the .sqlite files at the local end.
Thatâs the tricky bit - I think @Pectojin might know of a way to tease it out of the database but in general what would happen when running a backup job after attaching a different database would be one of these:
it does a backup without errors (yay - you guess correctly!)
it reports a FEW missing files at the destination (oops - your database is likely NEWER than your destination, how did you manage that?)
it reports a FEW extra files at the destination (oops - your database is like OLDER than your destination, itâs probably a backup or left over from an exported job)
it reports a LOT of missing or extra files at the destination (oops - totally wrong database, probably from a different job)
Duplicati wonât start and you eventually find some âdatabase versionâ errors (oops - database from a different version of Duplicati)
Other than #1 (where it worked) most of the above cases will have the Backup job aborted with an error and suggestion for a Database Repair - DONâT DO IT. As long as you donât run a Repair (or Recreate) you wonât be screwing anything up at either end and you can try again with a different database.
I found the database in exported job json file as @ts678 told in the first post. I just was searching in wrong place before. It worked perfectly without any error or warning.
Thank you @ts678 and @JonMikelV for help
