So with the release of the new beta I decided to upgrade from 2.0.3.5. However, after that finished I tried running one of my backups and got a “Failed: Unexpected difference in fileset version 14: 4/10/2018 2:00:00 AM (database id: 161), found 105124 entries, but expected 105125” error. Repair did nothing, so I tried running the recreate. It’s been running for 3 going on 4 days. The source is only 164GB and the backup is 187GB, with 16 versions. The destination is a NAS on the local network. My CPU usage shows 15%, and the disk and ethernet usage on my NAS also looks pretty negligible overall.
Checking the logs and setting it to profiling it looks like it’s running an insert query per chunk (49MB). Each of these queries is taking 30-40 seconds to run. This is just based on what shows in the logs so I don’t know if there’s anything else that might influence this. I’ll admit it’s hard to see exactly what this query is trying to do (looks like the general idea is looking to make sure the hash isn’t already in the db?), and my SQL isn’t the best, but it looks really ugly. Select statements nested 7 deep, with a union and an outer join.
INSERT INTO
"block" ("hash", "size", "volumeid")
SELECT
"fullhash" AS "Hash",
"length" AS "Size",
- 1 AS "VolumeID"
FROM
SELECT
"A"."fullhash",
"A"."length",
CASE
WHEN
"B"."hash" IS NULL
THEN
ELSE
"B"."hash"
END
AS "Hash",
CASE
WHEN
"B"."size" IS NULL
THEN
- 1
ELSE
"B"."size"
END
AS "Size"
FROM
SELECT DISTINCT
"fullhash",
"length"
FROM
SELECT
"blockhash" AS "FullHash",
"blocksize" AS "Length"
FROM
SELECT
"E"."blocksetid",
"F"."index" + ( "E"."blocklistindex" * 3200 ) AS "FullIndex",
"F"."blockhash",
Min(102400, "E"."length" - ( ( "F"."index" + ( "E"."blocklistindex" * 3200 ) ) * 102400 )) AS "BlockSize",
"E"."hash",
"E"."blocklistsize",
"E"."blocklisthash"
FROM
SELECT
FROM
SELECT
"A"."blocksetid",
"A"."index" AS "BlocklistIndex",
Min(3200 * 32,
( ( "B"."length" + 102400 - 1 ) / 102400 ) - ( "A"."index" * ( 3200 ) )
* 32 ) AS "BlocklistSize",
"A"."hash" AS "BlocklistHash",
"B"."length"
FROM
"blocklisthash" A,
"blockset" B
WHERE
"B"."id" = "A"."blocksetid"
C,
"block" D
WHERE
"C"."blocklisthash" = "D"."hash"
AND "C"."blocklistsize" = "D"."size"
E,
"tempblocklist - f672c0e9da6ec741ad0420aacddaf83b" F
WHERE
"F"."blocklisthash" = "E"."hash"
ORDER BY
"E"."blocksetid",
"fullindex"
UNION
SELECT
"blockhash",
"blocksize"
FROM
"tempsmalllist - 8f523a800627b14e910898be1249d607"
A
LEFT OUTER JOIN
"block" B
ON "B"."hash" = "A"."fullhash"
AND "B"."size" = "A"."length"
WHERE
"fullhash" != "hash"
AND "length" != "size"
Has there been much look into the performance of this? Spending multiple days to restore after a database corruption for only a 180GB backup seems really excessive.
