Setting up OneDrive (personal)
Hi all,
I’m returning to this thread after a long time because I happened to stumble on something. I came across this page: Connecting securely to Microsoft OneDrive with WebDAV :: WinSCP. It describes how to connect to OneDrive using WebDAV with WinSCP. I gave it a quick go, and it seems to work fine. However, it doesn’t work in Duplicati, returning a “Failed to connect: The remote server returned an error: (404) Not Found.” (message from the ‘Test connection’ button). A quick search suggests that WinSCP also had this issue but that they were able to fix it (WebDAV to OneDrive cause error :: Support Forum :: WinSCP).
Does anyone know if there is a particular reason that this approach does not work with Duplicati?
I was reading through the commit that fixed it for WinSCP, and it looks like it just adds “passport” auth to the allowed auth methods.
Without testing, I would assume that it would work on Windows (at least) by setting:
--integrated-authentication=true
Can you try that?
I gave it a go but it didn’t immediately seem to work. I kept receiving 404 Not Found errors (attempting a backup in a directory that should exist), with or without the flag set. I cannot completely exclude that I am setting things up incorrectly though.
It may be worth noting that I recently found some time and motivation to take a better look at the OAuthHandler, and ended up writing my own service (with significant help from your version, especially to figure out what Duplicati expected of the service). It ended up being an interesting project to try out some things that I had been wanting to try for a while anyway. So far, that approach seems to be working alright. As a result, it is less important to get things working in another way, though it’s still interesting.
Ok, I have added an issue so we can investigate:
Fun project! But could you not use the stand-alone version of the server?
Was the Test Connection feature removed? I migrated Duplicati from one PC to another yesterday and ran into trouble with OneDrive authentication. I eventually got it fixed, but couldn’t find the Test Connection functionality. That was pretty useful when it existed because you could test whether Duplicati could open the remote repo without having to run a full backup.
If you mean this on the old UI Destination screen:
it moved up a bit on the new UI Destination screen:
It’s renamed, but I think it actually does more now…
About Duplicati → Changelog
  • Improved backend test function
This isn’t really by new UI, but new UI describes new test. Old was just a file list, basically a sanity test on the connection (like you said). New one exercises files.
2025-05-29 - 2.1.0.119_canary_2025-05-29
Better backend Test
The test feature has been updated to now check for write permissions, instead of just listing the remote folder. For ngclient, the Test check now uses this extended check to inform the user if there are files in the destination folder. This shows a warning if creating a new backup pointing to a folder with existing data, and a warning if attempting to restore from a folder with no files. If the write part fails for a test during the restore flow, this is not treated as an error in ngclient.
Like many of you, the transition from the v1 API to the v2 Graph API, dealing with the InvalidAuthenticationToken errors, and the whole “slash vs. backslash” folder path debacle was incredibly frustrating. I also totally relate to the struggles of juggling multiple Microsoft accounts (like the “Charlie and Fred” scenario @BatterPudding mentioned) just to keep backups segregated and secure without browser autofill messing up the AuthID tokens.
One major headache that often comes up during these API transitions—or when you finally decide to bite the bullet and move your backups from a standard Personal account to a dedicated Family or Business tenant to bypass some of these OAuth/quota headaches—is the nightmare of physically moving the data. Having to download and re-upload hundreds of gigabytes of Duplicati backup sets just to change accounts is a massive drain on local bandwidth and time.
If anyone here is looking to reorganize their backup destinations, or needs to move their existing Duplicati data from one OneDrive account to another without having to re-upload everything from scratch, I highly recommend looking into the SysTools OneDrive Migration Tool.
It’s an absolute lifesaver for account-to-account or tenant-to-tenant transfers. It keeps your entire folder structure completely intact in the cloud. Once you use it to migrate your backup folders over to the new account, all you have to do in Duplicati is:
  1. Change the destination account.
  2. Generate a new AuthID for the new account.
  3. Point it to the exact same folder path and run a quick database repair.
