I run Duplicat’s Docker container on a Synology NAS to backup files from NAS>B2.
Restore works well, but I want also the option to restore to a Windows PC on my network. This doesn’t seem possible using the Docker container. Or is it?
To work around this, I installed Duplicati on the Windows PC and pointed it to the B2 bucket/folder. Now it is… “Recreating database … Building partial temporary database” … after which I expect the files will be restored to the Windows PC.
Is it possible to restore to the Windows PC using the Synology Docker container? If so, how would I do that?
EDIT: Using the Windows Duplicati failed. I got a bunch of files, but they are unusable.
Attempt2: I exported the database from the Synology Docker installation, and then tried to restore from a Win10 PC using restore from configuration, and pointing it to the exported database. After some time, that failed with the following…
WARNINGS
2019-10-19 21:07:43 -04 - [Warning-Duplicati.Library.Main.Database.LocalRecreateDatabase-MissingVolumesDetected]: Found 17 missing volumes; attempting to replace blocks from existing volumes
2019-10-19 21:27:18 -04 - [Warning-Duplicati.Library.Main.Database.LocalRecreateDatabase-MissingVolumesDetected]: Found 17 missing volumes; attempting to replace blocks from existing volumes
ERRORS
2019-10-19 20:32:44 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-baecea07c2c784aa3b2b9196a8d4091f7.dblock.zip.aes by duplicati-i170648bb19494b40a0125ab04d0026d3.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:32:58 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-b757f6fe4fcda4af080c2bf89d82d8c5a.dblock.zip.aes by duplicati-i18aab1a487144d5281cbdde866857edd.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:33:04 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-b33d8efe603204723beb9c322cc40d13a.dblock.zip.aes by duplicati-i1954a4195f764b66be307f9fac201702.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:33:53 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-bbeafe345b8ce4ee98f61a0a986acebbe.dblock.zip.aes by duplicati-i2058da57b892492fa0fa623005708eef.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:34:20 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-bd174e72720b44f1a83fc57e99514404a.dblock.zip.aes by duplicati-i237afb1c02424449a1e39b91808ec287.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:35:07 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-bbdd67b05adb04a31a28f8b9383718fb7.dblock.zip.aes by duplicati-i2a5998b87aac454f8e5c870de6975925.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:35:20 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-b0d43fd8d85064af1b4cb6e7153d002c2.dblock.zip.aes by duplicati-i2c9ad2fe0dca4d16a7ba1e6eb69695c6.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:36:19 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-bb27c2299c7c6427f9f95515e79c51635.dblock.zip.aes by duplicati-i355fe38501fa410a8ad403ca9e69976d.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:38:25 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-b44c33be1e78c43a88030a5b660f31474.dblock.zip.aes by duplicati-i4960c58d890d483ab4ead7afa801c3b3.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:40:10 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-b3c71d92d6162405d93598f767351a025.dblock.zip.aes by duplicati-i58e97ae17dbe43f594d558814ce9e42c.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:40:53 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-b33dc053243e84d0f9a16d07c5cd1ce22.dblock.zip.aes by duplicati-i5ee1e502571943dcb8047a2af3ba2e7c.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:42:16 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-bd05729e6450a4f38bd7e8199a1c8c609.dblock.zip.aes by duplicati-i6c42490d1c0741c9b6651b69d10e7f85.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:44:35 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-bb00028ed183c4f89b12f333c06ca8906.dblock.zip.aes by duplicati-i7f71398d3251478cb308a1a2647d88ad.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:53:18 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-b6b5e89aaf3434d47826a448ebca7e871.dblock.zip.aes by duplicati-icf9b539474dc4bff8ab29a555dc1a627.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:54:23 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-b2334a5b23ab848b89c3f43dc3111925e.dblock.zip.aes by duplicati-idb596bc75118460fb2d8d19d3439e15d.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:55:13 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-ba3c289e950834bae8cbbb8c170f698f7.dblock.zip.aes by duplicati-ie4c19e79dc03462d81bd30795cd5383b.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 20:55:30 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-MissingFileDetected]: Remote file referenced as duplicati-bc9838ef1c602438cae4a6478e3b4a65a.dblock.zip.aes by duplicati-ie735bb8fc2d94610ae3a89573cf59454.dindex.zip.aes, but not found in list, registering a missing remote file
2019-10-19 21:04:25 -04 - [Error-Duplicati.Library.Main.Operation.RecreateDatabaseHandler-IndexFileProcessingFailed]: Failed to process index file: duplicati-ifa8937515c4f4ebea6ec6e15347f5bce.dindex.zip.aes
When I checked the integrity of the source database it seemed fine (no errors).
