Hi all,
I’ve been using Duplicati successfully for quite some time. One of my destinations is a Netgear NAS - no issues at all.
Yesterday I replaced that NAS with a Synology Diskstation and am trying to modify the backup destination to the new NAS. Duplicati, when testing the connection, says:
“Failed to connect: Session operation has timed out”
All other permitted devices on the network can connect to the Synology NAS without issue. Only Duplicati can’t. Duplicati on this laptop has not changed. The IP address of the NAS is the same as the last one. I have removed all keys from ~/.ssh/known_hosts as well as “ssh-fingerprint” from the backup configuration.
Credentials have not changed and I’m not using key authentication - just username/password for now.
After I delete the “ssh-fingerprint” setting and use “Test connection” again, Duplicati does ask if I want to trust the host certificate. This suggests that connectivity is there, although something goes wrong after that point.
I’ve checked the Synology NAS and have tried high, medium and low security settings (the various levels specify which ciphers etc are accepted).
Any ideas what could be causing this?
Thanks!
Edit: Here’s the log entry related to the failure:
Renci.SshNet.Common.SshOperationTimeoutException: Session operation has timed out
at Renci.SshNet.Session.WaitOnHandle (System.Threading.WaitHandle waitHandle, System.TimeSpan timeout) [0x00065] in <1fab08b1278e43dabeb31c481785219b>:0
at Renci.SshNet.Session.Renci.SshNet.ISession.WaitOnHandle (System.Threading.WaitHandle waitHandle) [0x0000d] in <1fab08b1278e43dabeb31c481785219b>:0
at Renci.SshNet.Channels.Channel.WaitOnHandle (System.Threading.WaitHandle waitHandle) [0x00000] in <1fab08b1278e43dabeb31c481785219b>:0
at Renci.SshNet.Channels.Channel.GetDataLengthThatCanBeSentInMessage (System.Int32 messageLength) [0x00059] in <1fab08b1278e43dabeb31c481785219b>:0
at Renci.SshNet.Channels.Channel.SendData (System.Byte[] data, System.Int32 offset, System.Int32 size) [0x0000d] in <1fab08b1278e43dabeb31c481785219b>:0
at Renci.SshNet.Channels.Channel.SendData (System.Byte[] data) [0x00000] in <1fab08b1278e43dabeb31c481785219b>:0
at Renci.SshNet.SubsystemSession.SendData (System.Byte[] data) [0x0000c] in <1fab08b1278e43dabeb31c481785219b>:0
at Renci.SshNet.Sftp.SftpSession.SendMessage (Renci.SshNet.Sftp.SftpMessage sftpMessage) [0x00007] in <1fab08b1278e43dabeb31c481785219b>:0
at Renci.SshNet.Sftp.SftpSession.OnChannelOpen () [0x00007] in <1fab08b1278e43dabeb31c481785219b>:0
at Renci.SshNet.SubsystemSession.Connect () [0x000ea] in <1fab08b1278e43dabeb31c481785219b>:0
at Renci.SshNet.SftpClient.OnConnected () [0x0002e] in <1fab08b1278e43dabeb31c481785219b>:0
at Renci.SshNet.BaseClient.Connect () [0x00082] in <1fab08b1278e43dabeb31c481785219b>:0
at Duplicati.Library.Backend.SSHv2.CreateConnection () [0x000cc] in <cd4d7a20547f42cf8eac75b90eb5491d>:0
at Duplicati.Library.Backend.SSHv2.List () [0x0000c] in <cd4d7a20547f42cf8eac75b90eb5491d>:0
at Duplicati.Library.Backend.SSHv2.Test () [0x00000] in <cd4d7a20547f42cf8eac75b90eb5491d>:0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.TestConnection (System.String url, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) [0x000b7] in <a6c0c2089b9a44ec9be5057a44f12116>:0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.POST (System.String key, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) [0x00091] in <a6c0c2089b9a44ec9be5057a44f12116>:0
at Duplicati.Server.WebServer.RESTHandler.DoProcess (Duplicati.Server.WebServer.RESTMethods.RequestInfo info, System.String method, System.String module, System.String key) [0x0026e] in <a6c0c2089b9a44ec9be5057a44f12116>:0
