The database is marked as "in-progress" and may be incomplete. ErrorID: DatabaseIsInRepairState** The database was attempted repaired, but the repair did not complete. This database maybe incomplete and the repair process is not allowed to alter remote files as that could result in data loss.
Repair via graphical interface works and doesn’t throw anything at me. Backup works after repair. But when I try to use Repair command in CLI again, it gives error every time.
I type
Duplicati.CommandLine.exe repair remote
then it asks me for passphrase and then this error shows up.
Specifically, I suspect that the Local database path not being given on –dbpath is pointing you to some random database assigned to CLI storage URL on a previous CLI run. I think dbconfig.json maps these.
