Release: 2.2.0.2 (Beta) 2025-11-26
2.2.0.2_beta_2025-11-26
This is a beta release that primarily solves an issue with the new restore method, which could use up a significant amout of storage.
With this release, the option --restore-cache-max is added, which allows you to limit the amount of storage used during the restore process.
A few minor fixes are also included, which are detailed below.
Changes from 2.2.0.1 to 2.2.0.2
  • ServerUtil returns the backup status when waiting for completion, thanks @greyxr
  • Updated the Uplink.NET library to latest version (for Storj)
  • Disabled the built-in retry and timeout for Azure blob storage
  • Updated localizations
  • Added Rabata.io as an S3 provider
  • Added support for supplementary groups for service on Linux
  • Added support for limiting the restore process disk usage
Changes in user interface from 2.2.0.1 to 2.2.0.2
  • Updated to latest ShipUI
  • Preload modules for better desktop performance
  • Fixed some issues with localization not being applied
  • Updates to the options list
  • Updated localizations, thanks to all translators!
  • Fixed an issue with Rclone not maintaining letter-case for remote
  • Simplified the schedule setup page
  • Improved AuthID picking
  • Improved integration with console
  • Cleaned the sidebar slightly
  • Fixed an issue with styling in settings
  • Restore flow will now default to not overwrite existing files
  • Added both option name and short description to advanced options
  • Fixed not showing “Verifying” at the start of the backup operation
  • Handle global settings with and without -- prefix
  • Upgraded to Angular 21
  • Fixed loading Chinese language
  • Added different validation for B2 bucket names
  • Added support for hiding the console connection indicator
