Release: 2.0.7.0 (experimental) 2023-05-25
2.0.7.0-2.0.7.0_experimental_2023-05-25
After almost 2 years, a new Beta has taken its time, but it’s finally
there. It’s a roll-up of all the fixes since the last beta build and is
expected to cause very few issues when upgrading. This release is almost
identical to Canary 106.
It involves a better UI for dark mode, better support for Dropbox,
Jottacloud, S3, Tencent backends, add IDrive backend, TLS modernization,
bug fixes, upgrades to libraries.
Points of attention:
  • database upgrade from 11 to 12: Downgrade from this version requires
    manually adjusting the version
    number in the database. The additions can be re-applied if the database is
    upgraded again later.
Thanks for your work.
Pleasantly surprised by this update, thanks!
