Latest error:
{"ClassName":"System.AggregateException","Message":"One or more errors occurred.","Data":null,"InnerException":{"ClassName":"System.AggregateException","Message":"Could not find file 'C:\\Users\\m\\AppData\\Local\\Temp\\dup-e09bfc67-0c53-4020-9fda-82840d3df98d'.","Data":null,"InnerException":{"ClassName":"System.IO.FileNotFoundException","Message":"Could not find file 'C:\\Users\\m\\AppData\\Local\\Temp\\dup-e09bfc67-0c53-4020-9fda-82840d3df98d'.","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)\r\n at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)\r\n at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)\r\n at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<<Run>b__0>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at CoCoL.AutomationExtensions.<RunTask>d__10`1.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.BackupHandler.<RunMainOperation>d__13.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext()","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":"8\nWinIOError\nmscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\nSystem.IO.__Error\nVoid WinIOError(Int32, System.String)","HResult":-2147024894,"Source":"mscorlib","WatsonBuckets":null,"FileNotFound_FileName":"C:\\Users\\m\\AppData\\Local\\Temp\\dup-e09bfc67-0c53-4020-9fda-82840d3df98d","FileNotFound_FusionLog":null},"HelpURL":null,"StackTraceString":" at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext()","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":"8\nMoveNext\nDuplicati.Library.Main, Version=2.0.5.1, Culture=neutral, PublicKeyToken=null\nDuplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__20\nVoid MoveNext()","HResult":-2146233088,"Source":"Duplicati.Library.Main","WatsonBuckets":null,"InnerExceptions":[{"ClassName":"System.IO.FileNotFoundException","Message":"Could not find file 'C:\\Users\\m\\AppData\\Local\\Temp\\dup-e09bfc67-0c53-4020-9fda-82840d3df98d'.","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)\r\n at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)\r\n at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)\r\n at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<<Run>b__0>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at CoCoL.AutomationExtensions.<RunTask>d__10`1.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.BackupHandler.<RunMainOperation>d__13.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext()","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":"8\nWinIOError\nmscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\nSystem.IO.__Error\nVoid WinIOError(Int32, System.String)","HResult":-2147024894,"Source":"mscorlib","WatsonBuckets":null,"FileNotFound_FileName":"C:\\Users\\m\\AppData\\Local\\Temp\\dup-e09bfc67-0c53-4020-9fda-82840d3df98d","FileNotFound_FusionLog":null},{"ClassName":"System.AggregateException","Message":"One or more errors occurred.","Data":null,"InnerException":{"ClassName":"System.IO.IOException","Message":"Unable to read data from the transport connection: The connection was closed.","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at System.Net.ConnectStream.EndWrite(IAsyncResult asyncResult)\r\n at System.IO.Stream.<>c.<BeginEndWriteAsync>b__53_1(Stream stream, IAsyncResult asyncResult)\r\n at System.Threading.Tasks.TaskFactory`1.FromAsyncTrimPromise`1.Complete(TInstance thisRef, Func`3 endMethod, IAsyncResult asyncResult, Boolean requiresSynchronization)\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Utility.Utility.<CopyStreamAsync>d__11.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Utility.Utility.<CopyStreamAsync>d__10.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Backend.Backblaze.B2.<>c__DisplayClass28_0.<<PutAsync>b__1>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.JSONWebHelper.<GetJSONDataAsync>d__22`1.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Backend.Backblaze.B2.<PutAsync>d__28.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoPut>d__21.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<>c__DisplayClass17_0.<<UploadFileAsync>b__0>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoWithRetry>d__18.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoWithRetry>d__18.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<UploadFileAsync>d__17.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<UploadBlockAndIndexAsync>d__15.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at CoCoL.AutomationExtensions.<RunTask>d__10`1.MoveNext()","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":"8\nEndWrite\nSystem, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\nSystem.Net.ConnectStream\nVoid EndWrite(System.IAsyncResult)","HResult":-2146232800,"Source":"System","WatsonBuckets":null},"HelpURL":null,"StackTraceString":null,"RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":null,"HResult":-2146233088,"Source":null,"WatsonBuckets":null,"InnerExceptions":[{"ClassName":"System.IO.IOException","Message":"Unable to read data from the transport connection: The connection was closed.","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at System.Net.ConnectStream.EndWrite(IAsyncResult asyncResult)\r\n at System.IO.Stream.<>c.<BeginEndWriteAsync>b__53_1(Stream stream, IAsyncResult asyncResult)\r\n at System.Threading.Tasks.TaskFactory`1.FromAsyncTrimPromise`1.Complete(TInstance thisRef, Func`3 endMethod, IAsyncResult asyncResult, Boolean requiresSynchronization)\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Utility.Utility.<CopyStreamAsync>d__11.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Utility.Utility.<CopyStreamAsync>d__10.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Backend.Backblaze.B2.<>c__DisplayClass28_0.<<PutAsync>b__1>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.JSONWebHelper.<GetJSONDataAsync>d__22`1.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Backend.Backblaze.B2.<PutAsync>d__28.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoPut>d__21.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<>c__DisplayClass17_0.<<UploadFileAsync>b__0>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoWithRetry>d__18.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoWithRetry>d__18.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<UploadFileAsync>d__17.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<UploadBlockAndIndexAsync>d__15.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at CoCoL.AutomationExtensions.<RunTask>d__10`1.MoveNext()","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":"8\nEndWrite\nSystem, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\nSystem.Net.ConnectStream\nVoid EndWrite(System.IAsyncResult)","HResult":-2146232800,"Source":"System","WatsonBuckets":null}]}]},"HelpURL":null,"StackTraceString":" at CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task)\r\n at Duplicati.Library.Main.Controller.<>c__DisplayClass14_0.<Backup>b__0(BackupResults result)\r\n at Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Action`1 method)\r\n at Duplicati.Library.Main.Controller.Backup(String[] inputsources, IFilter filter)\r\n at Duplicati.Server.Runner.Run(IRunnerData data, Boolean fromQueue)","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":"8\nWaitForTaskOrThrow\nCoCoL, Version=1.7.1.0, Culture=neutral, PublicKeyToken=0983de3c914beeaa\nCoCoL.ChannelExtensions\nSystem.Threading.Tasks.Task WaitForTaskOrThrow(System.Threading.Tasks.Task)","HResult":-2146233088,"Source":"CoCoL","WatsonBuckets":null,"InnerExceptions":[{"ClassName":"System.AggregateException","Message":"Could not find file 'C:\\Users\\m\\AppData\\Local\\Temp\\dup-e09bfc67-0c53-4020-9fda-82840d3df98d'.","Data":null,"InnerException":{"ClassName":"System.IO.FileNotFoundException","Message":"Could not find file 'C:\\Users\\m\\AppData\\Local\\Temp\\dup-e09bfc67-0c53-4020-9fda-82840d3df98d'.","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)\r\n at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)\r\n at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)\r\n at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<<Run>b__0>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at CoCoL.AutomationExtensions.<RunTask>d__10`1.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.BackupHandler.<RunMainOperation>d__13.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext()","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":"8\nWinIOError\nmscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\nSystem.IO.__Error\nVoid WinIOError(Int32, System.String)","HResult":-2147024894,"Source":"mscorlib","WatsonBuckets":null,"FileNotFound_FileName":"C:\\Users\\m\\AppData\\Local\\Temp\\dup-e09bfc67-0c53-4020-9fda-82840d3df98d","FileNotFound_FusionLog":null},"HelpURL":null,"StackTraceString":" at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext()","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":"8\nMoveNext\nDuplicati.Library.Main, Version=2.0.5.1, Culture=neutral, PublicKeyToken=null\nDuplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__20\nVoid MoveNext()","HResult":-2146233088,"Source":"Duplicati.Library.Main","WatsonBuckets":null,"InnerExceptions":[{"ClassName":"System.IO.FileNotFoundException","Message":"Could not find file 'C:\\Users\\m\\AppData\\Local\\Temp\\dup-e09bfc67-0c53-4020-9fda-82840d3df98d'.","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)\r\n at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)\r\n at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)\r\n at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.<>c__DisplayClass0_0.<<Run>b__0>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at CoCoL.AutomationExtensions.<RunTask>d__10`1.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.BackupHandler.<RunMainOperation>d__13.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext()","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":"8\nWinIOError\nmscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\nSystem.IO.__Error\nVoid WinIOError(Int32, System.String)","HResult":-2147024894,"Source":"mscorlib","WatsonBuckets":null,"FileNotFound_FileName":"C:\\Users\\m\\AppData\\Local\\Temp\\dup-e09bfc67-0c53-4020-9fda-82840d3df98d","FileNotFound_FusionLog":null},{"ClassName":"System.AggregateException","Message":"One or more errors occurred.","Data":null,"InnerException":{"ClassName":"System.IO.IOException","Message":"Unable to read data from the transport connection: The connection was closed.","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at System.Net.ConnectStream.EndWrite(IAsyncResult asyncResult)\r\n at System.IO.Stream.<>c.<BeginEndWriteAsync>b__53_1(Stream stream, IAsyncResult asyncResult)\r\n at System.Threading.Tasks.TaskFactory`1.FromAsyncTrimPromise`1.Complete(TInstance thisRef, Func`3 endMethod, IAsyncResult asyncResult, Boolean requiresSynchronization)\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Utility.Utility.<CopyStreamAsync>d__11.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Utility.Utility.<CopyStreamAsync>d__10.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Backend.Backblaze.B2.<>c__DisplayClass28_0.<<PutAsync>b__1>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.JSONWebHelper.<GetJSONDataAsync>d__22`1.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Backend.Backblaze.B2.<PutAsync>d__28.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoPut>d__21.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<>c__DisplayClass17_0.<<UploadFileAsync>b__0>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoWithRetry>d__18.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoWithRetry>d__18.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<UploadFileAsync>d__17.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<UploadBlockAndIndexAsync>d__15.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<<Run>b__13_0>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at CoCoL.AutomationExtensions.<RunTask>d__10`1.MoveNext()","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":"8\nEndWrite\nSystem, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089\nSystem.Net.ConnectStream\nVoid EndWrite(System.IAsyncResult)","HResult":-2146232800,"Source":"System","WatsonBuckets":null},"HelpURL":null,"StackTraceString":null,"RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":null,"HResult":-2146233088,"Source":null,"WatsonBuckets":null,"InnerExceptions":[{"ClassName":"System.IO.IOException","Message":"Unable to read data from the transport connection: The connection was closed.","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at System.Net.ConnectStream.EndWrite(IAsyncResult asyncResult)\r\n at System.IO.Stream.<>c.<BeginEndWriteAsync>b__53_1(Stream stream, IAsyncResult asyncResult)\r\n at System.Threading.Tasks.TaskFactory`1.FromAsyncTrimPromise`1.Complete(TInstance thisRef, Func`3 endMethod, IAsyncResult asyncResult, Boolean requiresSynchronization)\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Utility.Utility.<CopyStreamAsync>d__11.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Utility.Utility.<CopyStreamAsync>d__10.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Backend.Backblaze.B2.<>c__DisplayClass28_0.<<PutAsync>b__1>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.JSONWebHelper.<GetJSONDataAsync>d__22`1.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Backend.Backblaze.B2.<PutAsync>d__28.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoPut>d__21.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<>c__DisplayClass17_0.<<UploadFileAsync>b__0>d.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoWithRetry>d__18.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<DoWithRetry>d__18.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<UploadFileAsync>d__17.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)\r\n at Duplicati.Library.Main.Operation.Backup.BackendUploader.<UploadBlockAndIndexAsync>d__15.MoveNext()\r\n--- End of stack trace from previous location where exception was thrown ---\r\n at
etc.
