Hi there,
First of all i wanted to say that i understand that this kind of question has been posted a million times already. I dont mean to spam the forum, i just can’t figure this out for my own situation.
I had a backup of 2.6TB data run for a couple days. It reached about 1TB or a bit less, and then the remote server stopped responding. Im not sure why yet. The remote server works again, i restarted the backup and now it’s been on “Verifying backend data…” for almost 24 hours. I understand that this can take a while for this much data, but i don’t see any progress. When i go to About -> System Info the lastPgEvent shows the following:
"BackupID":"2",
"TaskID":4,
"BackendAction":"Delete",
"BackendPath":"duplicati-i908f39b15044435482113627880d89e8.dindex.zip.aes",
"BackendFileSize":-1,
"BackendFileProgress":0,
"BackendSpeed":-1,
"BackendIsBlocking":true,
"CurrentFilename":null,
"CurrentFilesize":0,
"CurrentFileoffset":0,
"CurrentFilecomplete":false,
"Phase":"Backup_PreBackupVerify",
"OverallProgress":0,
"ProcessedFileCount":0,
"ProcessedFileSize":0,
"TotalFileCount":13585,
"TotalFileSize":2880800706093,
"StillCounting":false
Im specifically worried about ‘“BackendIsBlocking”:true,’. What does this mean? That doesn’t sound good.
Also ‘“OverallProgress”:0,’ stays at 0. Is this normal?
On the backend server i can see a constant stream of about 200 to 600 kb/s upload so something is definitely happening. I just can’t figure out if it’s stuck or not.
Thanks for any help.
