I am all of a sudden getting this warning on my Ubuntu machine (on two consecutive days):
2019-11-05 06.41.14 +02 - [Warning-Duplicati.Library.DynamicLoader.DynamicLoader1-SoftError]: Prosessin tyypin Duplicati.Library.Common.IO.VssBackupComponents lataus kirjastosta /usr/lib/duplicati/Duplicati.Library.IO.dll epäonnistui. Virheilmoitus oli: Could not load type of field ‘Duplicati.Library.Common.IO.VssBackupComponents:_vssBackupComponents’ (1) due to: Could not load file or assembly ‘AlphaVSS.Common, Version=1.4.0.0, Culture=neutral, PublicKeyToken=959d3993561034e3’ or one of its dependencies.`
I have never used the snapshot feature, and it’s several weeks since I have fiddled with Duplicati settings. I checked the /var/log/dpkg.log files (also the zipped ones), and found that the latest update to mono has been installed in August, and the latest update to any package was installed in October.
I cannot understand what could have changed to produce this type of warning?
I’m facing the same issue where this warning message is triggered about once a day on some machines. All my PC are using Linux Debian or Mint. I don’t use snapshots and most don’t even have LVM volumes. It’s been a long ongoing (several month) issue I’ve been too lazy to report until now.
2019-11-12 10:23:14 +01 - [Warning-Duplicati.Library.DynamicLoader.DynamicLoader`1-SoftError]: Failed to load process type Duplicati.Library.Common.IO.VssBackupComponents assembly /usr/lib/duplicati/Duplicati.Library.IO.dll, error message: Could not load type of field ‘Duplicati.Library.Common.IO.VssBackupComponents:_vssBackupComponents’ (1) due to: Could not load file or assembly ‘AlphaVSS.Common, Version=1.4.0.0, Culture=neutral, PublicKeyToken=959d3993561034e3’ or one of its dependencies.
