I recently got this error on a machine running 2.0.4.38. I searched the forum and didn’t see any other posts about NullReferenceException combined with StreamBlockSplitter so I thought I should start a new topic.
Failed: Object reference not set to an instance of an object.
Details: System.NullReferenceException: Object reference not set to an instance of an object.
at Duplicati.Library.Main.Operation.Backup.StreamBlockSplitter.<>c__DisplayClass2_0.<<Run>b__0>d.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.<RunMainOperation>d__13.MoveNext()
Log data:
2020-01-03 12:00:19 -08 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
I re-ran the backup job and it worked fine. Not sure what caused it. I don’t think I’ve ever seen this one before in my 2+ years of Duplicati use.
