I use Duplicati - 2.0.5.1_beta_2020-01-18, on Mac and on Win10, with B2 backblaze as a backup destination, i’m having the same issue on both computers when trying to restore (via “Direct restore from backup files”),
although I’m able to restore via “Restore from configuration” and uploading .json file.
The error message is “Failed to connect: 401 - bad_auth_token:”, from what I google its some kind of misleading documentation, account id, key id, app id etc but to be honest i’m a big confused now what to enter there…
I assume fileds: “Storage Type”, “Bucket name” and “Folder path” are straight forward and the real issue is with “B2 Application ID” and “B2 Application Key”,
→ “B2 application Key” is the password to the backup config I set on duplicati, right ?
→ “B2 Application ID” here I have tried, Master Application Key/KeyID from B2 backblaze settings, or Bucket ID from B2 setttings,
what is strange is that when those values are entered automatically via .json file it all works (connection fine) but when entered manually (via “Direct restore from backup files”) I get that error,
please help
thanks
