This is similar to No token to close. path '', however I have been running successful backups for some time.
I’m backing up to a local disk and it’s been backing up fine for 3 months. This past week I started getting this error message on the backups.
Newtonsoft.Json.JsonWriterException: No token to close. Path ''.
at Newtonsoft.Json.JsonWriter.CalculateLevelsToComplete (Newtonsoft.Json.JsonContainerType type) [0x00056] in <d47de75a7e3f422ca4ca64a654c80495>:0
at Newtonsoft.Json.JsonWriter.AutoCompleteClose (Newtonsoft.Json.JsonContainerType type) [0x00000] in <d47de75a7e3f422ca4ca64a654c80495>:0
at Newtonsoft.Json.JsonWriter.InternalWriteEnd (Newtonsoft.Json.JsonContainerType container) [0x00000] in <d47de75a7e3f422ca4ca64a654c80495>:0
at Newtonsoft.Json.JsonWriter.WriteEndArray () [0x00000] in <d47de75a7e3f422ca4ca64a654c80495>:0
at Duplicati.Library.Main.Volumes.FilesetVolumeWriter.AddFilelistFile () [0x00000] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Volumes.FilesetVolumeWriter.Close () [0x00008] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Volumes.FilesetVolumeWriter.Dispose () [0x00000] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__20.MoveNext () [0x00fbb] in <8f1de655bd1240739a78684d845cecc8>:0
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0011c] in <8f1de655bd1240739a78684d845cecc8>:0
Upgrade complete. I’ll watch how it behaves going forward.
I find it interesting that the run last night succeeded when the others for the past week failed. The main difference that I can think of is that there was less data to backup because I removed about 100GB of files.
I have a 35GB log file. I looked at the end of the file and don’t see much to help. Here is what I have. I can go farther back in the file to look, or grep for specific items. I’ve turned off the extra logging for future jobs.
2020-05-05 03:19:30 -05 - [Verbose-Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.FileEntry-AddDirectory]: Adding directory /usr/local/sbin/
2020-05-05 03:19:30 -05 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-IncludingPath]: Including path as no filters matched: /usr/local/sbin/backupDuplicatiDatabases.sh
2020-05-05 03:19:30 -05 - [Verbose-Duplicati.Library.Main.Operation.Backup.FilePreFilterProcess.FileEntry-CheckFileForChanges]: Checking file for changes /usr/local/sbin/backupDuplicatiDatabases.sh, new: False, timestamp changed: True, size changed: False, metadatachanged: True, 9/17/2019 10:07:32 AM vs 9/17/2019 10:07:32 AM
2020-05-05 03:19:30 -05 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-IncludingPath]: Including path as no filters matched: /usr/local/sbin/systemd-email
2020-05-05 03:19:30 -05 - [Verbose-Duplicati.Library.Main.Operation.Backup.FilePreFilterProcess.FileEntry-CheckFileForChanges]: Checking file for changes /usr/local/sbin/systemd-email, new: False, timestamp changed: True, size changed: False, metadatachanged: True, 9/17/2019 10:04:39 AM vs 9/17/2019 10:04:39 AM
2020-05-05 03:19:30 -05 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-FileMetadataChanged]: File has only metadata changes /usr/local/sbin/backupDuplicatiDatabases.sh
2020-05-05 03:19:30 -05 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-FileMetadataChanged]: File has only metadata changes /usr/local/sbin/systemd-email
2020-05-05 03:21:17 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-bf9852d8eedb54ad1aac08175dfdf84e0.dblock.zip (49.91 MB)
2020-05-05 03:21:21 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-bf9852d8eedb54ad1aac08175dfdf84e0.dblock.zip (49.91 MB)
2020-05-05 03:21:21 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-id3a359125b9345779761457195d5ab60.dindex.zip (1.97 MB)
2020-05-05 03:21:21 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-id3a359125b9345779761457195d5ab60.dindex.zip (1.97 MB)
2020-05-05 03:21:32 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b7c574d233b674c56ab84501ae209f22f.dblock.zip (31.94 MB)
2020-05-05 03:24:14 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b7c574d233b674c56ab84501ae209f22f.dblock.zip (31.94 MB)
2020-05-05 03:53:16 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-i401c874d946c41669b032c9d56a8f073.dindex.zip (1.11 MB)
2020-05-05 03:53:16 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-i401c874d946c41669b032c9d56a8f073.dindex.zip (1.11 MB)
2020-05-05 03:56:02 -05 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00fbb] in <8f1de655bd1240739a78684d845cecc8>:0
As a long shot, have you checked to make sure you’re not out of /tmp (or wherever yours lives) space?
Ordinarily I’d expect such an issue to cause issues with big files like the dblocks, but there are enough configuration options that one could probably set them to different spots to get different things failing…
Thanks for posting your log snippet. Not really any clues there. Hopefully a dev with more knowledge of the fileset volume writer can offer some ideas.
I tried starting a new backup and got the same error. I’m wondering if it has something to do with the number of files or files changing during the backup.
I wonder if you have a filename with a character causing issues for the Json writer.
Can you try removing items from your backup selection list to see if the problem eventually goes away? It may help identify a problem folder/file, if this is indeed the issue.
Nothing that I’ve been adding or removing lately has any special characters in the filenames. Doing a guess and check for this could take years with the amount of data being backed up. If I had a list of characters that are known to be good or known to be bad, I could check all of the filenames.
