Hello all,
I have a problem with backups running via SSH. I had recently upgraded my Linux distri (Linux Mint) since then I can no longer create backups that use SSH as the transfer protocol.
I had the same problem a few months ago. At that time it was because my old LTS version of Linux did not support a newer version of Mono and I had to update it manually. Since Duplicati is the only tool I use that is based on Mono, I was able to do this without any problems. The new Linux distri seems to have this new Mono version already, but now I get a very similar error message as back then.
I posted a screenshot and an output from the error message and the log entry, maybe someone else sees more than me or had the same problem.
System.AggregateException: One or more errors occurred. (Failure (Failure) (One or more errors occurred. (Failure))) ---> System.AggregateException: Failure (Failure) (One or more errors occurred. (Failure)) ---> Renci.SshNet.Common.SshException: Failure
at Renci.SshNet.Sftp.SftpSession.RequestOpen (System.String path, Renci.SshNet.Sftp.Flags flags, System.Boolean nullOnError) [0x00099] in <c60291af03764e69b153abec058a6ec5>:0
at Renci.SshNet.SftpClient.InternalUploadFile (System.IO.Stream input, System.String path, Renci.SshNet.Sftp.Flags flags, Renci.SshNet.Sftp.SftpUploadAsyncResult asyncResult, System.Action`1[T] uploadCallback) [0x0004f] in <c60291af03764e69b153abec058a6ec5>:0
at Renci.SshNet.SftpClient.UploadFile (System.IO.Stream input, System.String path, System.Boolean canOverride, System.Action`1[T] uploadCallback) [0x00017] in <c60291af03764e69b153abec058a6ec5>:0
at Renci.SshNet.SftpClient.UploadFile (System.IO.Stream input, System.String path, System.Action`1[T] uploadCallback) [0x00000] in <c60291af03764e69b153abec058a6ec5>:0
at Duplicati.Library.Backend.SSHv2.PutAsync (System.String remotename, System.IO.Stream stream, System.Threading.CancellationToken cancelToken) [0x00012] in <0d3e4ef338cb4d3cae538218575a1d08>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoPut (Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Interface.IBackend backend, System.Threading.CancellationToken cancelToken) [0x003a4] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader+<>c__DisplayClass20_0.<UploadFileAsync>b__0 () [0x0010a] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoWithRetry (System.Func`1[TResult] method, Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x0017c] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.DoWithRetry (System.Func`1[TResult] method, Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x003a5] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.UploadFileAsync (Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem item, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x000da] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.UploadBlockAndIndexAsync (Duplicati.Library.Main.Operation.Backup.VolumeUploadRequest upload, Duplicati.Library.Main.Operation.Backup.BackendUploader+Worker worker, System.Threading.CancellationToken cancelToken) [0x00098] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<Run>b__13_0 (<>f__AnonymousType12`1[<Input>j__TPar] self) [0x00780] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Library.Main.Operation.Backup.BackendUploader.<Run>b__13_0 (<>f__AnonymousType12`1[<Input>j__TPar] self) [0x007d7] in <60a7e79acb3b49e8af8a73149919d15b>:0
at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func`2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000d5] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0
at Duplicati.Library.Main.Operation.BackupHandler.FlushBackend (Duplicati.Library.Main.BackupResults result, CoCoL.IWriteChannel`1[T] uploadtarget, System.Threading.Tasks.Task uploader) [0x000f2] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00cb2] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01048] in <60a7e79acb3b49e8af8a73149919d15b>:0
at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task task) [0x0005d] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0026f] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Library.Main.Controller.Backup (System.String[] inputsources, Duplicati.Library.Utility.IFilter filter) [0x00074] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x00349] in <97751f2e2d7047e983f74950165267e2>:0
---> (Inner Exception #0) System.AggregateException: Failure (Failure) (One or more errors occurred. (Failure)) ---> Renci.SshNet.Common.SshException: Failure
---> (Inner Exception #0) Renci.SshNet.Common.SshException: Failure
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00cb2] in <60a7e79acb3b49e8af8a73149919d15b>:0 <---
---> (Inner Exception #1) System.AggregateException: One or more errors occurred. (Failure) ---> Renci.SshNet.Common.SshException: Failure
I’m currently running Duplicati - 2.0.5.112_canary_2021-01-20 on a
Linux Mint 20.1 machine.
I also googled the issue before but nothing I found, also in this forum worked (async-uploads 1, and some other stuff)
Thanks already for the support
Hovy
