Ok, I will try to be as specific as possible
Duplicati - 2.0.3.9_canary_2018-06-30
Here is some info on my backup
Source:2.78 TB
accept-any-ssl-certificate
Exclude Filter Groups:Default excludes
Remote volume size: 200 MB
Keep All Backups
–skip-metadata=true
–log-file=
–log-retention=15D
–tempdir=
I have also moved the Local database path to a drive with more space available
The backup tells me I need to repair, yet when I run repair it goes to about 75% (estimate from process bar) and I get the error…
The operation Repair has failed with error: Insertion failed because the database is full
database or disk is full
Here is an example of the log before this
Jul 21, 2018 12:21 AM: The operation Repair has failed with error: Insertion failed because the database is full
{"ClassName":"Mono.Data.Sqlite.SqliteException","Message":"Insertion failed because the database is full\r\ndatabase or disk is full","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" at Mono.Data.Sqlite.SQLite3.Reset (Mono.Data.Sqlite.SqliteStatement stmt) [0x00084] in <66d0f2b36dc5439784c7fcec2b0dd6bb>:0 \n at Mono.Data.Sqlite.SQLite3.Step (Mono.Data.Sqlite.SqliteStatement stmt) [0x0003d] in <66d0f2b36dc5439784c7fcec2b0dd6bb>:0 \n at Mono.Data.Sqlite.SqliteDataReader.NextResult () [0x00104] in <66d0f2b36dc5439784c7fcec2b0dd6bb>:0 \n at Mono.Data.Sqlite.SqliteDataReader..ctor (Mono.Data.Sqlite.SqliteCommand cmd, System.Data.CommandBehavior behave) [0x0004e] in <66d0f2b36dc5439784c7fcec2b0dd6bb>:0 \n at (wrapper remoting-invoke-with-check) Mono.Data.Sqlite.SqliteDataReader..ctor(Mono.Data.Sqlite.SqliteCommand,System.Data.CommandBehavior)\n at Mono.Data.Sqlite.SqliteCommand.ExecuteReader (System.Data.CommandBehavior behavior) [0x00006] in <66d0f2b36dc5439784c7fcec2b0dd6bb>:0 \n at Mono.Data.Sqlite.SqliteCommand.ExecuteNonQuery () [0x00000] in <66d0f2b36dc5439784c7fcec2b0dd6bb>:0 \n at Duplicati.Library.Main.Database.ExtensionMethods.ExecuteNonQuery (System.Data.IDbCommand self, System.String cmd, System.Object[] values) [0x00058] in <0ce58d578b8642d49036dc15fbad38f1>:0 \n at Duplicati.Library.Main.Database.LocalRecreateDatabase.FindMissingBlocklistHashes (System.Int64 hashsize, System.Int64 blocksize, System.Data.IDbTransaction transaction) [0x000a2] in <0ce58d578b8642d49036dc15fbad38f1>:0 \n at Duplicati.Library.Main.Operation.RecreateDatabaseHandler.DoRun (Duplicati.Library.Main.Database.LocalDatabase dbparent, System.Boolean updating, Duplicati.Library.Utility.IFilter filter, Duplicati.Library.Main.Operation.RecreateDatabaseHandler+NumberedFilterFilelistDelegate filelistfilter, Duplicati.Library.Main.Operation.RecreateDatabaseHandler+BlockVolumePostProcessor blockprocessor) [0x00e8a] in <0ce58d578b8642d49036dc15fbad38f1>:0 \n at Duplicati.Library.Main.Operation.RecreateDatabaseHandler.Run (System.String path, Duplicati.Library.Utility.IFilter filter, Duplicati.Library.Main.Operation.RecreateDatabaseHandler+NumberedFilterFilelistDelegate filelistfilter, Duplicati.Library.Main.Operation.RecreateDatabaseHandler+BlockVolumePostProcessor blockprocessor) [0x00037] in <0ce58d578b8642d49036dc15fbad38f1>:0 \n at Duplicati.Library.Main.Operation.RepairHandler.RunRepairLocal (Duplicati.Library.Utility.IFilter filter) [0x000ba] in <0ce58d578b8642d49036dc15fbad38f1>:0 \n at Duplicati.Library.Main.Operation.RepairHandler.Run (Duplicati.Library.Utility.IFilter filter) [0x00012] in <0ce58d578b8642d49036dc15fbad38f1>:0 \n at Duplicati.Library.Main.Controller+<>c__DisplayClass17_0.<Repair>b__0 (Duplicati.Library.Main.RepairResults result) [0x0001c] in <0ce58d578b8642d49036dc15fbad38f1>:0 \n at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0022e] in <0ce58d578b8642d49036dc15fbad38f1>:0 \n at Duplicati.Library.Main.Controller.RunAction[T] (T result, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x00007] in <0ce58d578b8642d49036dc15fbad38f1>:0 \n at Duplicati.Library.Main.Controller.Repair (Duplicati.Library.Utility.IFilter filter) [0x0001a] in <0ce58d578b8642d49036dc15fbad38f1>:0 \n at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x00399] in <8486dd191d20467cbf8d627f56ca2e90>:0 ","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":null,"HResult":-2147467259,"Source":"Mono.Data.Sqlite"}
Jul 21, 2018 12:21 AM: Running Repair took 0:06:05:17.768
Jul 21, 2018 12:21 AM: Recreate database for repair took 0:06:05:17.768
Jul 20, 2018 11:47 PM: ExecuteNonQuery: INSERT INTO "Block" ("Hash", "Size", "VolumeID") SELECT "FullHash" AS "Hash", "Length" AS "Size", -1 AS "VolumeID" FROM (SELECT "A"."FullHash", "A"."Length", CASE WHEN "B"."Hash" IS NULL THEN '' ELSE "B"."Hash" END AS "Hash", CASE WHEN "B"."Size" is NULL THEN -1 ELSE "B"."Size" END AS "Size" FROM (SELECT DISTINCT "FullHash", "Length" FROM (SELECT "BlockHash" AS "FullHash", "BlockSize" AS "Length" FROM (
SELECT
"E"."BlocksetID",
"F"."Index" + ("E"."BlocklistIndex" * 3200) AS "FullIndex",
"F"."BlockHash",
MIN(102400, "E"."Length" - (("F"."Index" + ("E"."BlocklistIndex" * 3200)) * 102400)) AS "BlockSize",
"E"."Hash",
"E"."BlocklistSize",
"E"."BlocklistHash"
FROM
SELECT * FROM
SELECT
"A"."BlocksetID",
"A"."Index" AS "BlocklistIndex",
MIN(3200 * 32, ((("B"."Length" + 102400 - 1) / 102400) - ("A"."Index" * (3200))) * 32) AS "BlocklistSize",
"A"."Hash" AS "BlocklistHash",
"B"."Length"
FROM
"BlocklistHash" A,
"Blockset" B
WHERE
"B"."ID" = "A"."BlocksetID"
) C,
"Block" D
WHERE
"C"."BlocklistHash" = "D"."Hash"
AND
"C"."BlocklistSize" = "D"."Size"
) E,
"TempBlocklist-D36A67C4A449FB40B5B98C47B8F1449D" F
WHERE
"F"."BlocklistHash" = "E"."Hash"
ORDER BY
"E"."BlocksetID",
"FullIndex"
) UNION SELECT "BlockHash", "BlockSize" FROM "TempSmalllist-B5AF581D85A1204BA0FBF4CC8E905424" )) A LEFT OUTER JOIN "Block" B ON "B"."Hash" = "A"."FullHash" AND "B"."Size" = "A"."Length" ) WHERE "FullHash" != "Hash" AND "Length" != "Size" took 0:00:23:34.583
Jul 20, 2018 11:24 PM: Starting - ExecuteNonQuery: INSERT INTO "Block" ("Hash", "Size", "VolumeID") SELECT "FullHash" AS "Hash", "Length" AS "Size", -1 AS "VolumeID" FROM (SELECT "A"."FullHash", "A"."Length", CASE WHEN "B"."Hash" IS NULL THEN '' ELSE "B"."Hash" END AS "Hash", CASE WHEN "B"."Size" is NULL THEN -1 ELSE "B"."Size" END AS "Size" FROM (SELECT DISTINCT "FullHash", "Length" FROM (SELECT "BlockHash" AS "FullHash", "BlockSize" AS "Length" FROM (
SELECT
"E"."BlocksetID",
"F"."BlockHash",
"E"."Hash",
"E"."BlocklistHash"
FROM
SELECT * FROM
SELECT
"A"."BlocksetID",
"B"."Length"
FROM
"BlocklistHash" A,
"Blockset" B
WHERE
) C,
"Block" D
WHERE
AND
) E,
WHERE
ORDER BY
"E"."BlocksetID",
"FullIndex"
Jul 20, 2018 11:24 PM: ExecuteScalarInt64: SELECT COUNT(*) FROM "RemoteVolume" WHERE "State" = "Temporary" AND "Type" = "Blocks" took 0:00:00:00.057
Jul 20, 2018 11:24 PM: Starting - ExecuteScalarInt64: SELECT COUNT(*) FROM "RemoteVolume" WHERE "State" = "Temporary" AND "Type" = "Blocks"
Jul 20, 2018 11:24 PM: CommitRecreatedDb took 0:00:01:13.756
Jul 20, 2018 11:23 PM: Starting - CommitRecreatedDb
Jul 20, 2018 11:23 PM: ExecuteScalarInt64: SELECT "ID" FROM "Remotevolume" WHERE "Name" = ? took 0:00:00:00.000
Jul 20, 2018 11:23 PM: Starting - ExecuteScalarInt64: SELECT "ID" FROM "Remotevolume" WHERE "Name" = ?
Jul 20, 2018 11:23 PM: ExecuteScalarInt64: SELECT "VolumeID" FROM "Block" WHERE "Hash" = ? AND "Size" = ? took 0:00:00:00.000
Jul 20, 2018 11:23 PM: Starting - ExecuteScalarInt64: SELECT "VolumeID" FROM "Block" WHERE "Hash" = ? AND "Size" = ?
The temp dir I am pointing has more than 3 TB free so I would think that I should not be running out of space?
