Hello , I am using Duplicati 2.0.4.23 Beta on Windows 10 Home to backup a folder with ca. 5 GB Data to Google Drive and a WebDAV destination with SSL. Both backups are with GPG encrypted and compressed with zip. The Backup using WebDAV always get three errors from Duplicati.Library.Main.Operation.TestHandler
saying, it can’t process three files (one .dlist
, one .dindex
and one .dblock
) because the sizes of the files aren’t the expected ones. I think this is the verification process. The files are always different. The other backup to Google Drive don’t get these errors, so I thought of a corrupt backup. I used the affected
command to find out wich files are affected by the dblock file and tried to restore it(because only one was affected). It went successful! Then I downloaded the dindex file and compared the expected size with the downloaded file’s size, it was the same! I don’t have a clue what is happening. Disable the verification would be a workaround, but i want to have the verification. Here is the log(parts in german):
DeletedFiles: 0
DeletedFolders: 0
ModifiedFiles: 0
ExaminedFiles: 59841
OpenedFiles: 0
AddedFiles: 0
SizeOfModifiedFiles: 0
SizeOfAddedFiles: 0
SizeOfExaminedFiles: 5260878333
SizeOfOpenedFiles: 0
NotProcessedFiles: 0
AddedFolders: 0
TooLargeFiles: 0
FilesWithError: 0
ModifiedFolders: 0
ModifiedSymlinks: 0
AddedSymlinks: 0
DeletedSymlinks: 0
PartialBackup: False
Dryrun: False
MainOperation: Backup
CompactResults: null
DeleteResults:
DeletedSets: []
Dryrun: False
MainOperation: Delete
ParsedResult: Error
Version: 2.0.4.23 (2.0.4.23_beta_2019-07-14)
EndTime: 30.08.2019 11:01:42 (1567155702)
BeginTime: 30.08.2019 11:01:42 (1567155702)
Duration: 00:00:00.4986623
Messages: [
2019-08-30 11:01:25 +02 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: Die Operation Backup wurde gestartet,
2019-08-30 11:01:27 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: (),
2019-08-30 11:01:28 +02 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (631 Bytes),
2019-08-30 11:01:42 +02 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-StartCheck]: Start checking if backups can be removed,
2019-08-30 11:01:42 +02 - [Information-Duplicati.Library.Main.Operation.DeleteHandler:RetentionPolicy-FramesAndIntervals]: Time frames and intervals pairs: 7.00:00:00 / 1.00:00:00, 28.00:00:00 / 7.00:00:00, 365.00:00:00 / 31.00:00:00,
Warnings: []
Errors: [
2019-08-30 11:02:30 +02 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-20190808T083941Z.dlist.zip.gpg,
2019-08-30 11:03:16 +02 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-i1b163e5e654a4f7e81106fefc5275185.dindex.zip.gpg,
2019-08-30 11:04:04 +02 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-b870fe3b452714c2e842d72055118acf5.dblock.zip.gpg
BackendStatistics:
RemoteCalls: 17
BytesUploaded: 0
BytesDownloaded: 7518465
FilesUploaded: 0
FilesDownloaded: 15
FilesDeleted: 0
FoldersCreated: 0
RetryAttempts: 12
UnknownFileSize: 0
UnknownFileCount: 0
KnownFileCount: 631
KnownFileSize: 2994211846
LastBackupDate: 28.08.2019 16:30:56 (1567002656)
BackupListCount: 3
TotalQuotaSpace: 0
FreeQuotaSpace: 0
AssignedQuotaSpace: -1
ReportedQuotaError: False
ReportedQuotaWarning: False
ParsedResult: Error
Messages: [
Warnings: []
Errors: [
RepairResults: null
TestResults:
MainOperation: Test
Verifications: [
Key: duplicati-20190808T083941Z.dlist.zip.gpg
Value: [
Key: Error
Value: Die Datei duplicati-20190808T083941Z.dlist.zip.gpg wurde heruntergeladen und hat die Größe 501051, erwartet war allerdings die Größe 5223626
Key: duplicati-i1b163e5e654a4f7e81106fefc5275185.dindex.zip.gpg
Value: [
Key: Error
Value: Die Datei duplicati-i1b163e5e654a4f7e81106fefc5275185.dindex.zip.gpg wurde heruntergeladen und hat die Größe 501321, erwartet war allerdings die Größe 14805
Key: duplicati-b870fe3b452714c2e842d72055118acf5.dblock.zip.gpg
Value: [
Key: Error
Value: Die Datei duplicati-b870fe3b452714c2e842d72055118acf5.dblock.zip.gpg wurde heruntergeladen und hat die Größe 501321, erwartet war allerdings die Größe 10361145
ParsedResult: Error
EndTime: 30.08.2019 11:04:04 (1567155844)
BeginTime: 30.08.2019 11:01:43 (1567155703)
Duration: 00:02:21.0124141
Messages: [
Warnings: []
Errors: [
ParsedResult: Error
BeginTime: 30.08.2019 11:01:25 (1567155685)
Duration: 00:02:38.9476090
Messages: [
Warnings: []
Errors: [
Here are the details of the downloaded dindex file:
(translation)
Value: [
Key: Error
Value: The file duplicati-i1b163e5e654a4f7e81106fefc5275185.dindex.zip.gpg was downloaded and has got the size 501321, expected, however, was the size 14805
