I have been running 2.0.5.1_beta_2020-01-18 for many months now with no issues on CentOS 7, backing up to Wasabi.
Over the weekend I had both backup jobs fail. I discovered that the root partition filled up (50G) most of it being the sqlite files. One was ~2GB and the other ~30GB. (should they get this big?).
I found another partition on the server with several TB free, so I went into each jobs database configuration and changed the local database path to this other partition. The files moved successfully.
My backup jobs are still failing and even doing a database repair fails.
One job runs for a bit then says “The requested folder does not exist”
Partial log info here
2020-09-15 07:18:29 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()
2020-09-15 07:18:30 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: ()
2020-09-15 07:20:42 -06 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation List has started
2020-09-15 07:20:58 -06 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Test has started
2020-09-15 07:20:58 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()
2020-09-15 07:20:58 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: ()
2020-09-15 07:21:03 -06 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Test has started
2020-09-15 07:21:03 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()
2020-09-15 07:21:03 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: ()
2020-09-15 07:21:05 -06 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Test has started
2020-09-15 07:21:05 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()
2020-09-15 07:21:05 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: ()
2020-09-15 07:23:16 -06 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Repair has started
2020-09-15 07:23:16 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()
2020-09-15 07:23:17 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: ()
2020-09-15 07:28:38 -06 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Repair has started
2020-09-15 09:29:40 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()
2020-09-15 09:29:41 -06 - [Retry-Duplicati.Library.Main.BackendManager-RetryList]: Operation List with file attempt 1 of 5 failed with message: The requested folder does not exist
Duplicati.Library.Interface.FolderMissingException: The requested folder does not exist —> Amazon.S3.AmazonS3Exception: The specified bucket does not exist —> Amazon.Runtime.Inte$
at System.Net.HttpWebRequest.GetResponseFromData (System.Net.WebResponseStream stream, System.Threading.CancellationToken cancellationToken) [0x00146] in <8a0944092ae944f79161e3ab1$
at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func
1[TResult] aborted, $
at System.Net.HttpWebRequest.GetResponse () [0x00016] in <8a0944092ae944f79161e3ab1237b7dd>:0
at Amazon.Runtime.Internal.HttpRequest.GetResponse () [0x00000] in :0
The second job show error “The database was attempted repaired, but the repair did not complete. This database may be incomplete and the backup process cannot continue. You may delete the local database and attempt to repair it again”
Log only shows that the job started and then an email was sent.
When I try a database repair on this job, I get “No files were found at the remote location, perhaps the target url is incorrect?”
I was able to create a new job and run it on a test directory (using the same bucket/key/secret) and it worked fine.
Any ideas where I can go from here?
