I’m having an error where after running the backup, it shows, “Found XXX missing files in remote storage.”. The backup destination is to Azure Blob Storage and the connections successfully work after I tested. Also, another issue with my backup to OneDrive for Business where it didn’t finish the backup. I’ve got the same error when I run it. I tried to search for possible fixes online but can’t find any. Any help will be much appreciated.
Thank you,
