Jottacloud native backend – sudden increase in HTTP 429 Too Many Requests
Thanks for the update, very useful to know.
It is a bit disappointing though, because I am seeing the same thing: even with a completely new backup job using 50 MB volumes and only one upload stream, I am still struggling to get it to run reliably.
So at least in my case, 50 MB + one upload stream improves things, but it does not appear to be a real solution either.
I am now testing with longer retry delays and exponential backoff, mainly to understand whether the problem is a short burst rate-limit or something more persistent on the Jottacloud side.
At this point, if this continues without a reliable workaround, I am getting quite close to thinking that Duplicati should reconsider whether the native Jottacloud backend can still be described as a supported/reliable destination. A backup backend that regularly fails because of server-side rate limiting, even with a single upload stream, is difficult to rely on in practice.
Thanks again for sharing your results, it helps a lot to know that I am not the only one seeing this behaviour.
Small update: I have now opened a bug report on GitHub for this issue:
I included the latest test results, including a completely new backup using 50 MB remote volumes, asynchronous-upload-limit = 1, exponential backoff and a 60 second retry delay.
Even with that setup, the backup still generated a very high number of retries and eventually failed.
Since Jottacloud support has confirmed that the HTTP 429 responses are caused by request rate limiting on their side, I thought it would be useful to have this tracked as a Duplicati issue as well — especially to look at whether the native Jottacloud backend could handle 429 / retry behaviour more robustly.
If anyone else can reproduce the same behaviour, it may be useful to add your findings to the GitHub issue as well.
Thanks for that!
We have been adding retry logic to Google and M365, so we can probably reuse that functionality directly on Jottacloud.
Thanks
If you need anything tested on the Jottacloud side while working on this, just let me know. I can reproduce the issue quite reliably and I’m happy to test specific builds, settings or retry scenarios.
The fix seems to work, but it takes ages to upload.
Saw a message log
# Message
Waiting for 03:56:33.5725949 to respect Retry-After header
Does this mean Duplicati waits ~4hours for the next file to upload?
And is this limit set by Jottacloud?
Yes, that is correct.
Yes, that is what Jottacloud reports. Most likely the response was “wait 14400 seconds” meaning 4 hours.
It is, IMO, a ridiculous amount of time to wait, but it does explain why retries were still rejected after 30 minutes.
For @ning42 and @FreaQ, do you have the “Unlimited” account?
Their website says “Upload speed gradually reduced”, but not that API requests are being throttled after a certain storage size.
Based on the timing of this happening, it points to a change on the Jottacloud side where it is more aggressive in limiting requests, but I could find no code in Duplicati that could explain it.
It is possible that Duplicati somehow mis-parses the back-off time, so the 4h is wrong, but seeing that 30m was not enough, I don’t have a good idea as to how the parsing should be wrong. Norway is UTC+1, so if your timezones are around UTC-2 or UTC+3 that could maybe indicate that the real wait is 1h (which is still a long time!).
The upload part of Duplicati is simple, but the download is using chunks of 5MB, which means the number of requests is larger. If the download part is the trigger, then setting jottacloud-threads=1 should limit the damage there.
If you have a support case with Jottacloud, then maybe hear if 4h wait is expected and what could be done to reduce it.
Yes, I do. There are ~60TB stored at the moment.
I strongly believe, that Jottacloud is trying to force out high consumption users. Making it for them (us) impossible to upload anything.
I am from Germany, so UTC+1 fits.
I tried, but they said, we only reduce upload speed, no rate limits. “Oh you are using a third party tool? Can’t help. Try the official app.”
The fact that Oldstuff failed again after a stable week suggests the volume size and single stream are only softening the rate, not preventing it. Your 1 GB test reproducing 429 right away is telling, since it points to request pattern rather than just concurrency. Worth checking whether the daily job is retrying failed files repeatedly, because retries against Jottacloud can keep the request count high even when upload speed looks low. Also thanks for the naming correction; worth confirming the actual option spelling in your job config so the limit is really applied rather than silently ignored. Does the failure cluster around listing or verification steps rather than uploads?
Yes, I have a unlimited storage plan. I currently have around 77 TB stored there.
I already have a support case with Jottacloud regarding the 429 responses.
I specifically asked them for information that would allow me to stay within their limits rather than trying to bypass them:
I am not trying to bypass the limitation — I would simply like to configure so that it stays within the limits instead of repeatedly receiving HTTP 429 responses.
For example, it would be useful to know whether the limit is based on:
  • requests per second/minute
  • number of concurrent uploads
  • requests over a longer time window
  • or some other threshold
Their official response was:
Thank you for your patience while we looked into this further. At this stage, we don’t have a specific published number for requests per second, per minute, or over a longer time window that defines the API rate limit triggering the 429 responses on your account.
What we can confirm is that this is a request-based limit, separate from the upload bandwidth restrictions that apply once an account exceeds certain storage thresholds. In terms of concurrency, the Jottacloud CLI’s default maximum for simultaneous uploads and downloads is 6, with an allowed range of 1 to 6, though as you noted this is a client-side setting rather than a guaranteed API threshold for your account.
Our terms of service also note that we reserve the right to apply limitations on bandwidth and the number of API calls to prevent excessive or abusive usage patterns, but no fixed recommended retry interval is specified.
I don’t have further detail beyond this at the moment, but please let me know if this helps or if you have any further questions.
They also referred me to:
So Jottacloud has explicitly confirmed that the 429 responses on my account are caused by a request-based limit, separate from the upload bandwidth restrictions that apply once certain storage thresholds are exceeded.
What they have not told me is the actual request threshold or how long a client is expected to wait after receiving a 429.
For reference, I am in Denmark and Jottacloud is in Norway, so we are in the same timezone. A timezone difference should therefore not explain the 4 hour value.
I have had the same thoughts as FreaQ. Of course, I cannot say whether this is intentional, but the practical effect for high-usage customers is starting to look very similar.”
It definitely looks like you are right in regards to Jottacloud trying to enforce their rules. However one finding does make it a little different.
For reference, I have 6TB in Jottacloud in total. Today only 260GB is using Duplicati.
I have decided to just use the Windows app and upload it. It works, however no Duplicati. I was using Duplicati to get easy retention settings (real backup and not only copy) and encryption.
I have made a test, only consisting of 200MB. I created a Duplicati backup, pointing to a local drive. Then uploading the files to Jottacloud using the Windows app. No errors at all, even it is the same files.
My conclusion is that this is a limitation they only have on Jottacloud (probably all non-native Jottacloud apps). That is not “remove large users”, that is “we only allow our own app”. Just my observations.
Thanks both for your responses.
It does not look very likely that the timestamp is parsed wrong then.
I did do a scan of the code, and it turns out that Duplicati is using an older API for uploading to Jottacloud. Comparing with rclone, I was able to guess at the new API shape and have added that as the default with --jottacloud-legacy-upload=true as a fallback in case something breaks.
My hope is that they are throttling the old API endpoint harder than the current one :crossed_fingers:
The next canary will have the fix.
