It seems like with the newest Opera release, my interface language cannot be changed from English to German. Maybe the Opera update is not the cause, but I don’t know anything else that has changed on my system. I also get two errors shown in the log everytime I refresh the site:
30. Sept. 2017 15:44: Request for http://localhost:8200/api/v1/systeminfo gave error
System.IndexOutOfRangeException: Der Index war außerhalb des Arraybereichs.
bei System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
bei Duplicati.Server.WebServer.RESTHandler.ParseRequestCulture(String acceptheader)
bei Duplicati.Server.WebServer.RESTMethods.SystemInfo.SystemData(RequestInfo info)
bei Duplicati.Server.WebServer.RESTMethods.SystemInfo.GET(String key, RequestInfo info)
bei Duplicati.Server.WebServer.RESTHandler.DoProcess(RequestInfo info, String method, String module, String key)
30. Sept. 2017 15:44: Reporting error gave error
System.ObjectDisposedException: In einen geschlossenen TextWriter kann nicht geschrieben werden.
bei System.IO.__Error.WriterClosed()
bei System.IO.StreamWriter.Flush(Boolean flushStream, Boolean flushEncoder)
Thanks in advance!
