First of all, Im a normal user who looks for a way to backup his synology to Onedrive. After checking some possibilities i found Duplicati, which looks promessing.
At the moment i try to install Duplicati on my Synology (DS412+ DSM 6.1.5) (Mono is up an running).
Unfortunatly im not able to install the package. Every time i try, it stopps after afew seconds.
Maybe someone has a suggestion how to solv that problem.
Please let us know if @Thomas_Boge’s post resolved your issue so we can flag it as the solution - or better yet, you can do it yourself by clicking on the icon (but grey / transparent, not blue) below his post. Note that you might have to click the “3 dots” button to expand all icons).
Unfortunately not. It crashes after a second. I wasnt able to execute the comandos in the FAQ. The directory that it refers to does not exist in my installation. Im still looking for a solution. I dont know yet if where the problem is. I will post it once I found it.
I haven’t gotten my hands on a Synology to play with yet but is there a command line you can try running Duplicati from? Or can you add the --verbose=true, --log-file=<path>, and --log-level=profiling parameters to the startup then check <path> after the crash to see if there is any detail about what happened?
(Note that the --log-* parameters may be different if you are using Duplicati v2.0.3 or newer.)
