I’d like to submit a low impact bug report for Duplicati. How to do so?
The bug is relatively dumb. In the HTML interface there is a lot of disconnect between the backend, and I just want to document an easy one to reproduce.
Duplicati uses GitHub Issues. Use the green New issue
button, and fill what you can into the template.
Exactly what the template likes, and I see you’ve done development, so you know why it helps resolution.
