Hi , I am using Duplicati in my Linux , Now if I want to restore any backed up data to my android , is there any way to do so ?
Thanks …
First, I’d note the subject said “from android”, but if you mean Duplicati on Linux is backing up Linux, restores can only go directly to a system running Duplicati, and I don’t think it’s been run on Android.
You can certainly restore to the Duplicati system, then find some other way to get files onto Android. Whether or not it’s worth working hard, e.g. on automation, might depend on how often this gets run.
