I’m trying to use duplicati-cli to search a remote SSH backup (database is local), using the following command-line:
duplicati-cli find ssh://[URL]/[PATH] --ssh-keyfile .ssh/id_dsa.pub --enable-module=console-password-input '*.txt'
I get the following error. Is there some way to have the CLI prompt me for the encryption passphrase? I thought console-password-input might do it, but apparently not.
Enter encryption passphrase:
System.InvalidOperationException: Cannot read keys when either application does not have a console or when console input has been redirected from a file. Try Console.Read.
at System.Console.ReadKey(Boolean intercept)
at Duplicati.Library.Modules.Builtin.ConsolePasswordInput.ReadPassphraseFromConsole(Boolean confirm)
at Duplicati.Library.Modules.Builtin.ConsolePasswordInput.Configure(IDictionary`2 commandlineOptions)
at Duplicati.Library.Main.Controller.SetupCommonOptions(ISetCommonOptions result, String[]& paths, IFilter& filter)
at Duplicati.Library.Main.Controller.List(IEnumerable`1 filterstrings, IFilter filter)
at Duplicati.CommandLine.Commands.List(TextWriter outwriter, Action`1 setup, List`1 args, Dictionary`2 options, IFilter filter)
