I am getting Unique constraint failed. Below is the log. Appreciate any help. Thanks.
code = Constraint (19), message = System.Data.SQLite.SQLiteException (0x800027AF): constraint failed
UNIQUE constraint failed: FilesetEntry.FilesetID, FilesetEntry.FileID
at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery(CommandBehavior behavior)
at Duplicati.Library.Main.Database.ExtensionMethods.ExecuteNonQuery(IDbCommand self, Boolean writeLog, String cmd, Object values)
at Duplicati.Library.Main.Database.LocalBackupDatabase.AddFile(Int64 pathprefixid, String filename, DateTime lastmodified, Int64 blocksetID, Int64 metadataID, IDbTransaction transaction)
at Duplicati.Library.Main.Database.LocalBackupDatabase.AddFile(String filename, DateTime lastmodified, Int64 blocksetID, Int64 metadataID, IDbTransaction transaction)
at Duplicati.Library.Main.Operation.Backup.BackupDatabase.<>c__DisplayClass8_0.b__0()
at Duplicati.Library.Main.Operation.Common.SingleRunner.<>c__DisplayClass3_0.b__0()
at Duplicati.Library.Main.Operation.Common.SingleRunner.d__21.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.<AddFolderToOutputAsync>d__5.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.<ProcessMetadata>d__3.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at Duplicati.Library.Main.Operation.Backup.MetadataPreProcess.<>c__DisplayClass2_0.<<Run>b__0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at CoCoL.AutomationExtensions.<RunTask>d__10
1.MoveNext()
at Duplicati.Library.Main.Operation.BackupHandler.d__13.MoveNext()
at Duplicati.Library.Main.Controller.<>c__DisplayClass14_0.b__0(BackupResults result)
at Duplicati.Library.Main.Controller.Backup(String inputsources, IFilter filter)
