I try to backup the folder c:\data\logseq
My problem is that I would like to exclude data that is stored in folders beneath this that are also named “logseq” , like *c:\data\logseq\work\logseq*
If I define a filter “exclude folder whose names contain = logseq” it doesn’t include anything in the backup, because all of the file match that search.
So I tried excluding files whose full string contains more than one \logseq\ with regex: (\\logseq\\.*\\logseq\\)
but it doesn’t seem to work in Duplicati event though it works on https://regexr.com/
Could someone help? thank you!
(is the a verbose-mode for the regex filter in duplicati, so I can see its results in the log?)
