The “Command line…” feature of the web GUI is a little rough around the edges, and I think you’ve bumped into one of those edges.
Try again but before you click the Run "test-filter" command now button clear out anything in the “Target URL >” field. (Don’t worry, this won’t be saved to your config - it’s a “just for this one run” change.)
