Hello,
For the Google Drive backup setup procedure, I noted that at Storage Providers - Duplicati 2 User's Manual, it said:
Supported format is: googledrive://folder/subfolder
The folder that exists on my Drive that I wish to back up to is:
Backups/LinuxMintPC
- Is it supposed to be like this:
googledrive://Backups/LinuxMintPC or googledrive://My-Drive/Backups/LinuxMintPC
One user stated mentioning paths said he had set up at /folder/subfolder/ so is there supposed to be a slash at end of last folder.
- What are the rules for spacing and capitalization? It is not made explicitly clear.
Do we put an underscore or hyphen?
- Are the folders on Google Drive already supposed to exist, or would Duplicati create a folder if we set that as the path for backups?
I searched through all of support and did not see any article mentioning any of that.
Thank you for any help in advance.
