Full test is ok, but restore doesn't work
Hello!
Full test
Duplicati.CommandLine.exe test “webdavs://…” all --full-remote-verification=true …
is ok
But restore doesn’t work
Please tell me what’s going on ?
e.g. test log:
Backend event: Get - Completed: duplicati-bc95319781aa34e8e88822a5a97b1da98.dblock.zip.aes (49,95 MB)
but on restore:
[Error-Duplicati.Library.Main.Operation.RestoreHandler-PatchingFailed]: Failed to patch with remote file: “duplicati-bc95319781aa34e8e88822a5a97b1da98.dblock.zip.aes”, message: Failed to decrypt data (invalid passphrase?): Invalid password or corrupted data
Most common cause is the browser password manager. It may be replacing the encryption password with the UI password without your knowledge. Can you try deleting the saved password for “localhost:8200” (or however you access the web UI) and try again?
Thank you.
Recreation of the base unexpectedly helped.
Although there were entries in the log about the wrong password.
Was that on top of the suggested browser change, or instead of it?
If you posted it, maybe someone could say whether it’s a problem. Don’t risk password accidents…
