Salvi
1
Good day
Since the update to the newest version I have the following problem:
FTP / SSL connection
Failed to connect: The underlying connection has been closed: The server has executed a protocol violation.
The old version is still top
I can log in with cyberduck
Thanks for your help:
Hello @Salvi - welcome to the forum!
Can you verify what your “old version” and “latest version” numbers are? (I’m assuming 2.0.3.3 and 2.0.4.5 but want to confirm it.)
Also, can you share the actual error message from the logs?
Salvi
3
here the log
thank you for your help
DeletedFiles: 5 DeletedFolders: 0 ModifiedFiles: 3 ExaminedFiles: 198365 OpenedFiles: 7
AddedFiles: 4 SizeOfModifiedFiles: 15905 SizeOfAddedFiles: 1144832 SizeOfExaminedFiles:
519538203716 SizeOfOpenedFiles: 1163403 NotProcessedFiles: 0 AddedFolders: 0 TooLargeFiles:
0 FilesWithError: 0 ModifiedFolders: 0 ModifiedSymlinks: 0 AddedSymlinks: 0 DeletedSymlinks:
0 PartialBackup: False Dryrun: False MainOperation: Backup CompactResults: DeletedFileCount:
0 DownloadedFileCount: 0 UploadedFileCount: 0 DeletedFileSize: 0 DownloadedFileSize: 0
UploadedFileSize: 0 Dryrun: False MainOperation: Compact ParsedResult: Warning Version:
2.0.4.5 (2.0.4.5_beta_2018-11-28) EndTime: 15.12.2018 08:45:20 (1544859920) BeginTime:
15.12.2018 08:45:06 (1544859906) Duration: 00:00:14.6796258 Messages: [ 2018-12-15 07:50:17
+01 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: Die Operation Backup
wurde gestartet, 2018-12-15 07:51:06 +01 - [Information-Duplicati.Library.Main.BasicResults-
BackendEvent]: Backend event: List - Started: (), 2018-12-15 07:51:15 +01 - [Information-
Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (1,03 KB),
2018-12-15 07:51:15 +01 - [Information-Duplicati.Library.Main.Operation.FilelistProcessor-
RemoteUnwantedMissingFile]: removing file listed as Temporary: duplicati-
20181211T152539Z.dlist.zip.aes, 2018-12-15 07:51:15 +01 - [Information-
Duplicati.Library.Main.Operation.FilelistProcessor-RemoteUnwantedMissingFile]: removing file
listed as Temporary: duplicati-bd0e8df8c9dfb49f6b4028f02e0b8be72.dblock.zip.aes, … ] Warnings:
[ 2018-12-15 07:51:15 +01 - [Warning-
Duplicati.Library.Main.Operation.Backup.UploadSyntheticFilelist-MissingTemporaryFilelist]:
Expected there to be a temporary fileset for synthetic filelist (77, duplicatii6935522e16de4da0a22ae4b333206914.
dindex.zip.aes), but none was found? ] Errors:
BackendStatistics: RemoteCalls: 9 BytesUploaded: 17051175 BytesDownloaded: 855928775
FilesUploaded: 3 FilesDownloaded: 3 FilesDeleted: 1 FoldersCreated: 0 RetryAttempts: 0
UnknownFileSize: 0 UnknownFileCount: 0 KnownFileCount: 1059 KnownFileSize: 437389616311
LastBackupDate: 15.12.2018 07:50:17 (1544856617) BackupListCount: 3 TotalQuotaSpace: 0
FreeQuotaSpace: 0 AssignedQuotaSpace: -1 ReportedQuotaError: False ReportedQuotaWarning:
False ParsedResult: Warning Version: 2.0.4.5 (2.0.4.5_beta_2018-11-28) Messages: [ 2018-12-15
07:50:17 +01 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: Die Operation
Backup wurde gestartet, 2018-12-15 07:51:06 +01 - [Information-
Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: (), 2018-12-15
07:51:15 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event:
List - Completed: (1,03 KB), 2018-12-15 07:51:15 +01 - [Information-
listed as Temporary: duplicati-20181211T152539Z.dlist.zip.aes, 2018-12-15 07:51:15 +01 -
[Information-Duplicati.Library.Main.Operation.FilelistProcessor-RemoteUnwantedMissingFile]:
removing file listed as Temporary: duplicatibd0e8df8c9dfb49f6b4028f02e0b8be72.
dblock.zip.aes, … ] Warnings: [ 2018-12-15 07:51:15 +01 -
[Warning-Duplicati.Library.Main.Operation.Backup.UploadSyntheticFilelist-
MissingTemporaryFilelist]: Expected there to be a temporary fileset for synthetic filelist (77,
duplicati-i6935522e16de4da0a22ae4b333206914.dindex.zip.aes), but none was found? ] Errors:
DeleteResults: DeletedSets: [ Item1: 3 Item2: 07.12.2018 23:00:04 (1544220004) ] Dryrun: False
MainOperation: Delete ParsedResult: Warning Version: 2.0.4.5 (2.0.4.5_beta_2018-11-28)
EndTime: 15.12.2018 08:45:20 (1544859920) BeginTime: 15.12.2018 08:44:07 (1544859847)
Duration: 00:01:13.4761291 Messages: [ 2018-12-15 07:50:17 +01 - [Information-
Duplicati.Library.Main.Controller-StartingOperation]: Die Operation Backup wurde gestartet,
2018-12-15 07:51:06 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]:
20181211T152539Z.dlist.zip.aes, 2018-12-15 07:51:15 +01 - [InformationDuplicati.
RepairResults: null TestResults: MainOperation: Test Verifications: [ Key: duplicati-
20181215T065017Z.dlist.zip.aes Value: , Key: duplicatii70278c66608c42d8b49760682c428e29.
dindex.zip.aes Value: , Key: duplicatibe298e794fc774f43ada48e5fd92676c5.
dblock.zip.aes Value: ] ParsedResult: Warning Version:
2.0.4.5 (2.0.4.5_beta_2018-11-28) EndTime: 15.12.2018 08:48:01 (1544860081) BeginTime:
15.12.2018 08:45:22 (1544859922) Duration: 00:02:38.6522786 Messages: [ 2018-12-15 07:50:17
ParsedResult: Warning Version: 2.0.4.5 (2.0.4.5_beta_2018-11-28) EndTime: 15.12.2018 08:48:01
(1544860081) BeginTime: 15.12.2018 07:50:16 (1544856616) Duration: 00:57:45.0976185
Messages: [ 2018-12-15 07:50:17 +01 - [Information-Duplicati.Library.Main.Controller-
StartingOperation]: Die Operation Backup wurde gestartet, 2018-12-15 07:51:06 +01 -
[Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started:
(), 2018-12-15 07:51:15 +01 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]:
Backend event: List - Completed: (1,03 KB), 2018-12-15 07:51:15 +01 - [Information-
