I have been trying to troubleshoot a recurring problem where duplicati seems to freeze mid-backup and requires the processes to restart to resume. I finally caught it in the act with Profiling log level enabled.
System:
Windows 10
Single user OS and all files backing up are under C:\users<user_name>
Duplicati - 2.0.4.5_beta_2018-11-28
Backing up via FTP over SSL (a few other clients backup successfully to the same FTP server)
Configuration and usage done via Web UI
Scheduled backups are enabled and set to run daily
There appears to be no backup activity for days. An initial backup has not yet completed yet (i.e. “Last successful run: Never”)
Symptoms:
The timestamp on the destination disk and the contents of the log show no recent activity. The Status was 0% for file DSC_0396.NEF upon my arrival and you can observe that file name in the log below.
Additional details:
Netstat -ano for connections to the destination IP showed only one (IP address redacted):
TCP 192.168.1.145:58396 x.x.x.x:21 ESTABLISHED 6540
Normally a netstat shows both command port 21 and a high data port. I stopped the backup in the UI which locked the database. I quit duplicati from the system tray, restarted the tray process and started the backup. The backup then resumed normally.
Log file below (last 30 lines). Note the last activity before I intervened was 12-20 and the timestamp corresponds with the last activity on the destination FTP disk. You can see today (12-22) when I stopped and tried to resume the backup but the database was locked. Sadly the log file contents don’t seem to indicate (to me) what caused things to freeze up. Thoughts?
2018-12-20 10:25:32 -06 - [Profiling-Duplicati.Library.Main.Operation.Common.BackendHandler-UploadSpeed]: Uploaded 38.25 KB in 00:00:06.1721901, 6.20 KB/s
2018-12-20 10:25:32 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-i7b6b563af8364ff7b7f5ccc9c81628eb.dindex.zip.aes (38.25 KB)
2018-12-20 10:25:32 -06 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: Starting - CommitAfterUpload
2018-12-20 10:25:32 -06 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: CommitAfterUpload took 0:00:00:00.234
2018-12-20 10:25:32 -06 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: SELECT "ID" FROM "Remotevolume" WHERE "Name" = "duplicati-b68b12895e8df45d5ac234f721bcd90d5.dblock.zip.aes"
2018-12-20 10:25:32 -06 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: SELECT "ID" FROM "Remotevolume" WHERE "Name" = "duplicati-b68b12895e8df45d5ac234f721bcd90d5.dblock.zip.aes" took 0:00:00:00.000
2018-12-20 10:25:32 -06 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-ba2297da1209c4d7882047fa69bf45472.dblock.zip.aes (50.00 MB)
2018-12-20 10:25:32 -06 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: INSERT INTO "Remotevolume" ("OperationID", "Name", "Type", "State", "Size", "VerificationCount", "DeleteGraceTime") VALUES (4, "duplicati-b3087a6404e194788a2f5b3d9dab5ae8a.dblock.zip.aes", "Blocks", "Temporary", -1, 0, 0); SELECT last_insert_rowid();
2018-12-20 10:25:32 -06 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: INSERT INTO "Remotevolume" ("OperationID", "Name", "Type", "State", "Size", "VerificationCount", "DeleteGraceTime") VALUES (4, "duplicati-b3087a6404e194788a2f5b3d9dab5ae8a.dblock.zip.aes", "Blocks", "Temporary", -1, 0, 0); SELECT last_insert_rowid(); took 0:00:00:00.078
2018-12-20 10:25:35 -06 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-NewFile]: New file C:\Users\Luke and Debbi\Pictures\2018-09\DSC_0395.NEF
2018-12-20 10:25:35 -06 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-IncludingPath]: Including path as no filters matched: C:\Users\Luke and Debbi\Pictures\2018-09\DSC_0397.NEF
2018-12-20 10:25:35 -06 - [Verbose-Duplicati.Library.Main.Operation.Backup.FilePreFilterProcess.FileEntry-CheckFileForChanges]: Checking file for changes C:\Users\Luke and Debbi\Pictures\2018-09\DSC_0396.NEF, new: True, timestamp changed: True, size changed: True, metadatachanged: True, 9/15/2018 3:21:52 AM vs 1/1/0001 12:00:00 AM
2018-12-20 10:25:38 -06 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-NewFile]: New file C:\Users\Luke and Debbi\Pictures\2018-09\DSC_0396.JPG
2018-12-20 10:25:38 -06 - [Verbose-Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess-IncludingPath]: Including path as no filters matched: C:\Users\Luke and Debbi\Pictures\2018-09\DSC_0398.JPG
2018-12-20 10:25:38 -06 - [Verbose-Duplicati.Library.Main.Operation.Backup.FilePreFilterProcess.FileEntry-CheckFileForChanges]: Checking file for changes C:\Users\Luke and Debbi\Pictures\2018-09\DSC_0397.JPG, new: True, timestamp changed: True, size changed: True, metadatachanged: True, 9/15/2018 3:22:06 AM vs 1/1/0001 12:00:00 AM
2018-12-20 10:25:41 -06 - [Profiling-Timer.Begin-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: Starting - CommitAddBlockToOutputFlush
2018-12-20 10:25:46 -06 - [Profiling-Timer.Finished-Duplicati.Library.Main.Operation.Common.DatabaseCommon-CommitTransactionAsync]: CommitAddBlockToOutputFlush took 0:00:00:04.702
2018-12-22 15:37:41 -06 - [Profiling-Timer.Finished-Duplicati.Library.Main.Controller-RunBackup]: Running Backup took 3:05:38:22.578
2018-12-22 15:37:45 -06 - [Warning-Duplicati.Library.Main.Controller-DeprecatedOption]: The option log-level is deprecated: Use the log-file-log-level and console-log-level options instead
2018-12-22 15:37:45 -06 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started
2018-12-22 15:37:45 -06 - [Profiling-Timer.Begin-Duplicati.Library.Main.Controller-RunBackup]: Starting - Running Backup
2018-12-22 15:37:45 -06 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: INSERT INTO "Operation" ("Description", "Timestamp") VALUES ("Backup", 1545514665); SELECT last_insert_rowid();
2018-12-22 15:38:15 -06 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: INSERT INTO "Operation" ("Description", "Timestamp") VALUES ("Backup", 1545514665); SELECT last_insert_rowid(); took 0:00:00:30.051
2018-12-22 15:38:15 -06 - [Profiling-Timer.Finished-Duplicati.Library.Main.Controller-RunBackup]: Running Backup took 0:00:00:30.246
2018-12-22 15:38:17 -06 - [Warning-Duplicati.Library.Main.Controller-DeprecatedOption]: The option log-level is deprecated: Use the log-file-log-level and console-log-level options instead
2018-12-22 15:38:17 -06 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started
2018-12-22 15:38:17 -06 - [Profiling-Timer.Begin-Duplicati.Library.Main.Controller-RunBackup]: Starting - Running Backup
2018-12-22 15:38:17 -06 - [Profiling-Timer.Begin-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: Starting - ExecuteScalarInt64: INSERT INTO "Operation" ("Description", "Timestamp") VALUES ("Backup", 1545514697); SELECT last_insert_rowid();
2018-12-22 15:38:47 -06 - [Profiling-Timer.Finished-Duplicati.Library.Main.Database.ExtensionMethods-ExecuteScalarInt64]: ExecuteScalarInt64: INSERT INTO "Operation" ("Description", "Timestamp") VALUES ("Backup", 1545514697); SELECT last_insert_rowid(); took 0:00:00:30.062
2018-12-22 15:38:47 -06 - [Profiling-Timer.Finished-Duplicati.Library.Main.Controller-RunBackup]: Running Backup took 0:00:00:30.066
