Hi, I restarted a backup HDD to HDD, which I cancelled via GUI yesterday. It does not continue. What can I do? Start from scratch would be inconvenient, because it already took some hours to backup… 2 tries, different messages. Latest .17 Canary:
System.OverflowException: Das Negieren des minimalen Wertes einer Ergänzungszahl ist unzulässig.
bei Duplicati.Library.Main.Operation.BackupHandler.HandleFilesystemEntry(ISnapshotService snapshot, BackendManager backend, String path, FileAttributes attributes)
bei Duplicati.Library.Main.Operation.BackupHandler.RunMainOperation(ISnapshotService snapshot, BackendManager backend)
bei Duplicati.Library.Main.Operation.BackupHandler.Run(String[] sources, IFilter filter)
bei Duplicati.Library.Main.Controller.<>c__DisplayClass17_0.<Backup>b__0(BackupResults result)
bei Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Action`1 method)
bei Duplicati.Library.Main.Controller.Backup(String[] inputsources, IFilter filter)
bei Duplicati.Server.Runner.Run(IRunnerData data, Boolean fromQueue)
Fatal error
Duplicati.Library.Interface.UserInformationException: Found 3 remote files that are not recorded in local storage, please run repair
bei Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, String protectedfile)
bei Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify(BackendManager backend, String protectedfile)
