I’m running them with the bash that comes with git on windows
Well apparently I’m a sadist so finally after one long and annoying Windows 10 update I got the subsystem installed, tried running ./extract_all.sh and…
me@mymachine: ./extract_all.sh
./duplicati/extract.sh: line 14: xgettext: command not found
./webroot/extract.sh: line 6: angular-gettext-cli: command not found
Sigh. I expect it’ll run just fine on one of my Linux VMs.
It’s not that I want to take over translation processing or anything - I just want to “fully” test my single period change. ![]()
I’m waiting for the first post about installing the .deb package or using Linux paths on Windows… ![]()
For those that might still want to play around with it…
The Windows 10 'bash' installation text
Microsoft Windows [Version 10.0.15063]
(c) 2017 Microsoft Corporation. All rights reserved.
C:\Users\me>bash
– Beta feature –
This will install Ubuntu on Windows, distributed by Canonical
and licensed under its terms available here:
https://aka.ms/uowterms
Type “y” to continue: y
Downloading from the Windows Store… 100%
Extracting filesystem, this will take a few minutes…
Please create a default UNIX user account. The username does not need to match your Windows username.
For more information visit: Set up a WSL development environment | Microsoft Learn
Enter new UNIX username: me
Enter new UNIX password:
Retype new UNIX password:
passwd: password updated successfully
Installation successful!
The environment will start momentarily…
Documentation is available at: Install WSL | Microsoft Learn
To run a command as administrator (user “root”), use “sudo ”.
See “man sudo_root” for details.
me@myPC:/mnt/c/Users/me$
I remember something about being able to apt-get install xgettext from the Windows subsystem?
I’m using these windows binaries:
plus node.js with this:
not sure if you can run them from the windows subsystem? Otherwise Ken’s probposal sounds good…
