Hello to all!
I’m now runnig Duplicati - 2.0.3.3_beta_2018-04-02.
Tried to test the restore functionality and faced up with a problem, described in topic title. Below are some screenshots and log info. Any help will be greatly appreciated.
I frogot to mention, I’m running Ubuntu 16.04.
Some peice of Live Log:
Apr 13, 2018 5:42 PM: Running List took 00:00:00.386
Apr 13, 2018 5:42 PM: ExecuteNonQuery: DROP TABLE IF EXISTS "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634" took 00:00:00.000
Apr 13, 2018 5:42 PM: Starting - ExecuteNonQuery: DROP TABLE IF EXISTS "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634"
Apr 13, 2018 5:42 PM: ExecuteReader: SELECT DISTINCT "A"."FilesetID", "B"."FileCount", "B"."FileSizes" FROM "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634" A LEFT OUTER JOIN ( SELECT "A"."FilesetID" AS "FilesetID", COUNT(*) AS "FileCount", SUM("C"."Length") AS "FileSizes" FROM "FilesetEntry" A, "File" B, "Blockset" C WHERE "A"."FileID" = "B"."ID" AND "B"."BlocksetID" = "C"."ID" AND "A"."FilesetID" IN (SELECT DISTINCT "FilesetID" FROM "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634") GROUP BY "A"."FilesetID" ) B ON "A"."FilesetID" = "B"."FilesetID" ORDER BY "A"."Timestamp" DESC took 00:00:00.024
Apr 13, 2018 5:42 PM: Starting - ExecuteReader: SELECT DISTINCT "A"."FilesetID", "B"."FileCount", "B"."FileSizes" FROM "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634" A LEFT OUTER JOIN ( SELECT "A"."FilesetID" AS "FilesetID", COUNT(*) AS "FileCount", SUM("C"."Length") AS "FileSizes" FROM "FilesetEntry" A, "File" B, "Blockset" C WHERE "A"."FileID" = "B"."ID" AND "B"."BlocksetID" = "C"."ID" AND "A"."FilesetID" IN (SELECT DISTINCT "FilesetID" FROM "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634") GROUP BY "A"."FilesetID" ) B ON "A"."FilesetID" = "B"."FilesetID" ORDER BY "A"."Timestamp" DESC
Apr 13, 2018 5:42 PM: ExecuteNonQuery: DROP TABLE IF EXISTS "Filenames-2D640D089C58B74C8644F5832B0AF37F" took 00:00:00.012
Apr 13, 2018 5:42 PM: Starting - ExecuteNonQuery: DROP TABLE IF EXISTS "Filenames-2D640D089C58B74C8644F5832B0AF37F"
Apr 13, 2018 5:42 PM: ExecuteScalarInt64: SELECT COUNT(*) FROM "Filenames-2D640D089C58B74C8644F5832B0AF37F" WHERE SUBSTR("Path", 1, ?) = ? took 00:00:00.005
Apr 13, 2018 5:42 PM: Starting - ExecuteScalarInt64: SELECT COUNT(*) FROM "Filenames-2D640D089C58B74C8644F5832B0AF37F" WHERE SUBSTR("Path", 1, ?) = ?
Apr 13, 2018 5:42 PM: ExecuteScalarInt64: SELECT COUNT(*) FROM "Filenames-2D640D089C58B74C8644F5832B0AF37F" WHERE SUBSTR("Path", 1, ?) = ? took 00:00:00.006
Apr 13, 2018 5:42 PM: ExecuteScalarInt64: SELECT COUNT(*) FROM "Filenames-2D640D089C58B74C8644F5832B0AF37F" WHERE SUBSTR("Path", 1, ?) = ? took 00:00:00.007
Apr 13, 2018 5:42 PM: ExecuteScalarInt64: SELECT COUNT(*) FROM "Filenames-2D640D089C58B74C8644F5832B0AF37F" took 00:00:00.001
Apr 13, 2018 5:42 PM: ExecuteNonQuery: DELETE FROM "Filenames-2D640D089C58B74C8644F5832B0AF37F" WHERE "Path" NOT IN (SELECT DISTINCT "Path" FROM "File", "FilesetEntry" WHERE "FilesetEntry"."FileID" = "File"."ID" AND "FilesetEntry"."FilesetID" IN (SELECT "FilesetID" FROM "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634") ) took 00:00:00.196
Apr 13, 2018 5:42 PM: Starting - ExecuteNonQuery: DELETE FROM "Filenames-2D640D089C58B74C8644F5832B0AF37F" WHERE "Path" NOT IN (SELECT DISTINCT "Path" FROM "File", "FilesetEntry" WHERE "FilesetEntry"."FileID" = "File"."ID" AND "FilesetEntry"."FilesetID" IN (SELECT "FilesetID" FROM "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634") )
Apr 13, 2018 5:42 PM: ExecuteNonQuery: INSERT INTO "Filenames-2D640D089C58B74C8644F5832B0AF37F" SELECT DISTINCT "Path" FROM "File" WHERE "Path" LIKE ? took 00:00:00.040
Apr 13, 2018 5:42 PM: Starting - ExecuteNonQuery: INSERT INTO "Filenames-2D640D089C58B74C8644F5832B0AF37F" SELECT DISTINCT "Path" FROM "File" WHERE "Path" LIKE ?
Apr 13, 2018 5:42 PM: ExecuteNonQuery: CREATE TEMPORARY TABLE "Filenames-2D640D089C58B74C8644F5832B0AF37F" ("Path" TEXT NOT NULL) took 00:00:00.000
Apr 13, 2018 5:42 PM: Starting - ExecuteNonQuery: CREATE TEMPORARY TABLE "Filenames-2D640D089C58B74C8644F5832B0AF37F" ("Path" TEXT NOT NULL)
Apr 13, 2018 5:42 PM: ExecuteNonQuery: DELETE FROM "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634" WHERE "FilesetID" NOT IN (SELECT "FilesetID" FROM "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634" ORDER BY "Timestamp" DESC LIMIT 1 ) took 00:00:00.000
Apr 13, 2018 5:42 PM: Starting - ExecuteNonQuery: DELETE FROM "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634" WHERE "FilesetID" NOT IN (SELECT "FilesetID" FROM "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634" ORDER BY "Timestamp" DESC LIMIT 1 )
Apr 13, 2018 5:42 PM: ExecuteNonQuery: CREATE INDEX "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634_FilesetIDTimestampIndex" ON "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634" ("FilesetID", "Timestamp" DESC) took 00:00:00.000
Apr 13, 2018 5:42 PM: Starting - ExecuteNonQuery: CREATE INDEX "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634_FilesetIDTimestampIndex" ON "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634" ("FilesetID", "Timestamp" DESC)
Apr 13, 2018 5:42 PM: ExecuteNonQuery: CREATE TEMPORARY TABLE "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634" AS SELECT DISTINCT "ID" AS "FilesetID", "Timestamp" AS "Timestamp" FROM "Fileset" WHERE "Timestamp" <= ? took 00:00:00.000
Apr 13, 2018 5:42 PM: Starting - ExecuteNonQuery: CREATE TEMPORARY TABLE "Filesets-D31F6F0DBEA6D8499A41AFC944A2F634" AS SELECT DISTINCT "ID" AS "FilesetID", "Timestamp" AS "Timestamp" FROM "Fileset" WHERE "Timestamp" <= ?
Apr 13, 2018 5:42 PM: ExecuteReader: SELECT "ID", "Timestamp" FROM "Fileset" ORDER BY "Timestamp" DESC took 00:00:00.000
Apr 13, 2018 5:42 PM: Starting - ExecuteReader: SELECT "ID", "Timestamp" FROM "Fileset" ORDER BY "Timestamp" DESC
Apr 13, 2018 5:42 PM: ExecuteScalarInt64: INSERT INTO "Operation" ("Description", "Timestamp") VALUES (?, ?); SELECT last_insert_rowid(); took 00:00:00.047
Apr 13, 2018 5:42 PM: Starting - ExecuteScalarInt64: INSERT INTO "Operation" ("Description", "Timestamp") VALUES (?, ?); SELECT last_insert_rowid();
Apr 13, 2018 5:42 PM: Starting - Running List
Apr 13, 2018 5:42 PM: Running List took 00:00:00.072
